Old 12-29-2016, 21:21   #1 (permalink)
nasro_nd's Avatar
Member: 149415
Sonork: 100.1609895
Thanks Meter: 77
i9500 comletly dead chinse miracle version
hello guys
it was more than 6 years I did not work with chinese miracle
I hope you can help me to repair my i9500
its a MT6589
my client tried to flash it with a free software he forgot his name
now the phone is OFF but when I connect it to my pc I hear the sound as a new device found
I would like to flash it if possible via test point but I need to know which version of chinese miracle have to use
I downloaded the CM2MTK 1.25 but there is no way to connect with TEst point it there only USB mode
thanks
Old 12-29-2016, 23:56   #2 (permalink)
nasro_nd's Avatar
Member: 149415
Sonork: 100.1609895
Thanks Meter: 77
Card found: S/N 1xxxxxx
Chinese Miracle II [MTK module] v 1.25
Operation : Flash Erase [ v1.25 ]
User accepted Flash Erase operation!
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 5300014534304D4566822847CF905B0D
DA Stat : v3.2 on BBID : 0x86
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00B8
Error : DA init Failed! Error code : 0x5
LErr : EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Old 12-30-2016, 14:54   #3 (permalink)
nasro_nd's Avatar
Member: 149415
Sonork: 100.1609895
Thanks Meter: 77
any one can give me the correct rom for my phone
thanks
Old 12-30-2016, 15:11   #4 (permalink)
Member: 1988630
Sonork: 100.1664547
Thanks Meter: 299
Preloader Status : Not active (Erased) firmware here
The Following User Says Thank You to adfd For This Useful Post:
Old 12-30-2016, 15:36   #5 (permalink)
nasro_nd's Avatar
Member: 149415
Sonork: 100.1609895
Thanks Meter: 77
thanks sir
how can I fix this Preloader Statuts ?
your link doesn't work
Old 12-30-2016, 15:44   #6 (permalink)
Member: 1988630
Sonork: 100.1664547
Thanks Meter: 299
Originally Posted by nasro_nd View Post
thanks sir
you have preloader backup flash this file if no backup flash this file
Old 12-30-2016, 16:07   #7 (permalink)
nasro_nd's Avatar
Member: 149415
Sonork: 100.1609895
Thanks Meter: 77
error when I tried flash it
thanks
Page generated in 0.31864 seconds with 8 queries
