05-24-2018, 19:20 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: MVR
Member: 266180 Status: Offline Thanks Meter: 25 | Ibrit af51 Frp Lock not remove Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
05-25-2018, 02:23 | #4 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
But forgot where it is, will check today | |
05-25-2018, 06:37 | #7 (permalink) |
Member: 266180 Status: Offline Thanks Meter: 25 | Finally Frp Done with CM2 thanks for the support @kamal_singla Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642025A501A52F841D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642025A501A52F841D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0xE12D6E17E8624A0DBBFBCEDBB939ECDF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to ntothel For This Useful Post: |
10-18-2018, 09:43 | #11 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | No need to pay for such a single DA file.... Quote:
Free JUST PRESS THANKS ****************************/file/bvwdj...DA_SP.rar/file | |
The Following 7 Users Say Thank You to Ransiri For This Useful Post: |
11-05-2018, 07:03 | #12 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Link updated due to forum member request https://mega.nz/#!1WJ11KwR Key - 58erDAk_MV4mqJBhMzbs8-I6kT5s4RrMsGVJSzVlJng |
The Following 3 Users Say Thank You to Ransiri For This Useful Post: |
12-06-2018, 17:35 | #13 (permalink) |
Freak Poster Join Date: Feb 2010 Location: sharjha
Member: 1236922 Status: Offline Sonork: sajer007 Thanks Meter: 101 | Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM9) Boot mode: Preloader BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (57Gb+8192Mb) UNKNOWN_EMMC_DEVICE EMMC FW VERSION: 25:00:00:00:00:00:00:00 EMMC CID: 8801034E4361726420 : 00000000000000 EMMC UA SIZE: 0x1ce100000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1ced00000 [7.231 GB] Checking data, wait... Writing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
12-07-2018, 01:39 | #14 (permalink) | |
02-07-2019, 08:45 | #15 (permalink) |
Freak Poster Join Date: Oct 2008 Location: chenai,india
Member: 883886 Status: Offline Sonork: 1664059 Thanks Meter: 111 | UMT box Ibrit Alpha AF51 Frp Remove https://www.4shared.com/rar/pZhZwOvE...One_DA_SP.html Operation : Reset FRP CPU : MT6580 Storage : EMMC DA : MTK_AllInOne_DA_SP.bin [MTK_AllInOne_DA_v3.3001.00.00] Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM13) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Alpha Manufacturer : Alpha Model : iBRIT_AF51 Prod. Name : full_t960w_v1_n_frog_m01l_1s Device : t960w_v1_n_frog_m01l_1s Platform : mt6580 Android Ver. : 7.0 Display ID : iBRIT_AF51_V04_20170712 Patch Level : 2017-05-05 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.5] |
