Idea Fab 3G i4901 "Secure Boot" or "BootLoader Locked" phone Dear Friends, It's Idea i4901. Operation : Check / Read Info [ v1.21 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Check / Read Info [ v1.21 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Read Flash [ v1.21 ] Code: 1. Power Off Phone , Remove battery , Insert back |
Hello, what is problem in result? First log can be result of connection or battery problem as well. There is no any exactly though about that. |
When I Click On "Identify" Then I Connect With USB Cable & Insert Battery So It's Always Show "Secure Boot" or "BootLoader Locked" phone But When I "First" Connect Cellphone With USB Cable & Insert Battery Wait 2Sec "Then" Click On "Identify' So It's Show, Initial Info read Ok! |
Ok, thanks for explain. Will check that. |
Jaydi please guide how to flash Micromax A1 & how to unlock bootloader? |
Operation : Check / Read Info [ v1.37 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Check / Read Info [ v1.37 ] Code: 1. Power Off Phone , Remove battery , Insert back Want To Unlock "SECURE BOOT" If Someone Help Me Please. |
Dear Friends, Every Day Getting This Cellphones With Virus Infected Or Hang At Logo. More R&D On It. :) One More Step For Searching Solution. Operation : Check / Read Info [ v1.45 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : FastBoot : ReadInfo [ v1.45 ] Code: Power Off Phone , re-connect battery , Insert USB cable! Operation : FastBoot : Unlock BootLoader [ v1.45 ] Code: Power Off Phone , re-connect battery , Insert USB cable! I Have Full Dump Read From Working Cellphone So Should I Try To Write On Faulty Cellphone ? Code: MT6572__COMPAL__i4901__ALPS.JB3.MP.V1.17__Android_4.2.2__24.06.2014.ispff |
I Have Full Dump Read From Working Cellphone So Should I Try To Write On Faulty Cellphone ? Code: MT6572__COMPAL__i4901__ALPS.JB3.MP.V1.17__Android_4.2.2__24.06.2014.ispff Yes,if its the same preloader and version.then post result |
Handset In Hand Need File For Test......Already Done Format & Virus Clean Then Also Hang On Logo Can U Upload The Above Readed File N Share Link For Me... |
Dear Friends, This Firmware & Full Dump Won't Help On This Cellphone. Request To All, Don't Try With Any Firmware Until We Get Safe Way To Flash It. |
So If U Have Readed Full File Kindly Share.... Or You Have Factory File Or Official Rom? |
