11-17-2014, 21:41 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: lake
Member: 983215 Status: Offline Thanks Meter: 49 | ideas tecno mt6572 on old to new soft ver' alcatel ot-918 also got similar connect errors[ but with nck dongle ok] tecno h5 got successful connection. Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! what can cause this boot errors? |
11-18-2014, 16:19 | #3 (permalink) | |
Member: 983215 Status: Offline Thanks Meter: 49 | Quote:
Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6573 BB_CPU_HW : FC00 BB_CPU_SW : FC00 BB_CPU_SB : FC00 BB_CPU_NM : [MediaTek] MTxxx Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Error : Correct DA sequence not found for target! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! | |
11-18-2014, 16:33 | #4 (permalink) |
Member: 983215 Status: Offline Thanks Meter: 49 | this is tecno t721[working ok status] logs Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 31 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : A17B1FEDDCA09AEA2C6648986BCC6F9E BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! *one of commzero'' Scanning Mobile USB Port... >>> Detecting COM PortCOM31 Mobile Connection Success... CPU_ID:MT6255 Hardware Version:8A00 Software Version:CA03 >>> Downloading First Boot... Verifying First Boot... boot_init_3--eer!!! >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWN ================NAND Flash Info================= Flash Size:0x08000000 -> 128M Flash ID:0x00C800B100800055 Flash Name:NAND_STFM64D1G12A ot-918 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM31 Mobile Connection Success... CPU_ID:MT6573 Hardware Version:CA10 Software Version:CA01 >>> Downloading First Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWN ================NAND Flash Info================= Flash Size:0x20000000 -> 512M Flash ID:0x002C00BC00900055 Flash Name:NAND_SamSungMT29C4G48MAZAPAKD |
