Old 02-27-2008, 10:24   #1 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
If Bleu 245x support on Infiniry Box . . . ? ? ? ?
Hello ,
I have check the bleu and it's model list on infinity box....................
I can't found this model on this list.
This model have a restart problem --- >>>>> When i insert the battry it show searching network and within 20 - 25 sec phone is restart.
Have any solution for this model Infinity Support.
Thankx in advance.
Old 02-27-2008, 11:45   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
http://67.15.194.130/vbb/showthread.php?t=505500
Is it unlocked or simlocked phone ?
Did you tried to make 112 (emergency) call without sim card ? What is the results ?
Read flash from ths phone and send to [email protected] to check
Old 02-27-2008, 12:02   #3 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
without sim phone still freez on bleu.
and with sim it also restart.
And also i don't know pinout's of this model ----- ::: OR ::: ----- which cable i use for this model.
Thankx for the fast reply.
Old 02-27-2008, 13:14   #4 (permalink)
Member: 130995
@amol_sm
download latest updates from Infinity-Box support area and you will get pinout information for this model.
Old 03-04-2008, 16:44   #5 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
I have download the latest update from support area.
in Pmobule i see this model but another question is --------- Which cable i use for connecting.
please send the name of this cable.
Old 03-04-2008, 17:16   #6 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
I try to connect this model with following cable. (I posted cable name)
AT106 - BenQ M300
AT106 - TS10
AT108 - VK2000
AT106 - 343i(2)
AT108 - VK2020
AT106 - O2X4
In above cable any cable not match with this model.
Thankx in advance.
Old 03-04-2008, 19:13   #7 (permalink)
Member: 130995
AT106 - BenQ M300
AT106 - TS10
AT108 - VK2000
AT106 - 343i(2)
AT108 - VK2020
AT106 - O2X4
Thankx in advance.
Hello,
Yes, I understand that you have many cables... But I can't understand why you ignore Infinity-Box engineer's advices ? Please, explain !
How to get correct pinout: run Infinity-Box Shell, select required model and you will see detailed infornmation about cables/pinouts.
Old 03-05-2008, 06:45   #8 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Originally Posted by InfinitySupport View Post
Hello,
No sir i don't ignore u r instruction. But u will see the where is detail of this model. (For more detail here is the screenshot of selected model.)
I open Infinity Shell and select desire model but in the shell no detail about this model. And also i download the laest pinout from support area.
Too many confusion about this model .............. whn i solve my problem.
Thankx in advance Infinity Team.
Old 03-05-2008, 09:16   #9 (permalink)
Member: 484733
Thanks Meter: 10
Sir, in my shell it is showing that the require cable is ZTE 7310.
Old 03-05-2008, 10:29   #10 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
What is the problem Infinity team.
Why i can't show the pinout detail in my shell window.
Also i have installed the new Pinout V1.26
Then where is problem and where is the solution....... ?
Old 03-05-2008, 11:21   #11 (permalink)
Member: 130995
1. download latest Pinouts module update
2. download latest PModule02 module update
3. Close Infinity-Box Shell !
4. Install Pinouts module
5. Install PModule02
Old 03-05-2008, 11:48   #12 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Yes this time i have reached the cable information.
and also i have tell u that here is my phone problem.
http:///vbb/showpo...05&postcount=1
Also thankx for fast replying.
Old 03-05-2008, 12:11   #13 (permalink)
Member: 130995
1. make full backup and eepom backup
2. flash phone with "repair ffs" file
3. test phone
4. if still no luck: flash with "repair eeprom" file
5. test phone
23 Feb 2008: Bleu-151x, Bleu-245x flash read/write supported InfinitySupport Infinity-Box 45 02-10-2009 15:27
Bleu 245x freeze only on BLEU name halpppppppppppppp d.jain Infinity-Box 1 10-06-2008 16:13
@ infinity -Bleu 245x freeze only on BLEU Screen???? vikramb1 Infinity-Box 0 09-11-2008 19:34
nead update for bleu 245x sp unlock nazar2008 Infinity-Box 2 01-13-2008 15:17
Unlock MX7931, 7941- now support on Delok box. sed_alex DELOK DONGLE 3 12-07-2004 07:50
Page generated in 0.39284 seconds with 8 queries
