12-22-2016, 21:01 | #1 (permalink) | ||
Major Poster Join Date: Dec 2004 Location: hungary Age: 40
Member: 95826 Status: Offline Thanks Meter: 0 | ILike X3 PRO SLIM FRP lock The phone is SPD7731G android 6. Im try SC7730...7731 eMMC Generic SC7730...7731 eMMC Generic android 5. SC7730...7731 eMMC Generic crev android 6. SC77XX select model wit all 7731 pac. But nothing. Always error. Quote:
Any idea? | ||
12-29-2016, 22:05 | #2 (permalink) |
Junior Member Join Date: Oct 2006
Member: 375408 Status: Offline Thanks Meter: 5 | Same problem ! Chinese Miracle II [SPD module] v 1.24 Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
12-29-2016, 22:35 | #3 (permalink) |
Member: 375408 Status: Offline Thanks Meter: 5 | Loading : X3_PRO_SLIM.V1.0_20161018.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : X3_PRO_SLIM.V1.0_20161018 FastCheck : 0x0093ECCC8B Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_sc7731g_AndroidM.dat File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : persist.img File : sysinfo.img File : userdata.img File : logo_uboot.bmp File : logo_kernel.bmp File : cache.img File : u-boot.bin File : logo_kernel3.bmp File : logo_kernel4.bmp File : logo_kernel5.bmp File : SC7731_2300M.xml Load Ok! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : Size : 0x0000000020000000 State : 0x0001 Mount : Size : 0x0000000008F0D000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Use this firmware select in flash pac and frp done . http://www.needrom.com/download/ilike-x3-pro/ |
The Following User Says Thank You to cobravio For This Useful Post: |
