Phone show intex logo i try to formate
ist -identify
report fail i salect p1 p2 p3 or auto detect but fail
operation : Check / read info [ v1.10 ]
1. Power off phone , remove battery , insert back
2. Insert usb cable. In some cases require hold bootkey
wait for phone...
Phone found! [ 35 ]
sync...
Inital regs read done
boot info :
Bb_cpu_id : 6572
bb_cpu_hw : Ca01
bb_cpu_sw : 8a00
bb_cpu_sb : 0000
bb_cpu_nm : [mediatek] mt6572_s00
processing brom stage
blversion : 0x01
seccfgval : 0x00000000
bromversion : 0xff
blversion : 0x01
preloader status : Alive
processing da stage
da select done , sending
nand_id : 009800bc009000660076001600080000
emmc_id : 00000000000000000000000000000000
da stat : V4.2 on bbid : 0x88
da sent. Configure setting now ...
Da started successuflly
nand flashic initialized
[nand] : Flash_ven : 0x0011 , [kingston] ktn0403cs_tcr1
[nand] : Flash_die : 0098 00bc 0090 0066 0076 0016 0008
[nand] : Flash_len : 0x20000000
int ram : 0x00020000
ext ram : 0x10000000
boot type : Nand_flash_boot
soc verify : C1
boot ok!
Nand : Detecting structure now... Please, wait.
Nand : Structure detect failed! Send report to support!
Initial info read ok!
Done!
Elapsed: 00:00:31
reconnect power/cable! |
I ALSO CHACK IN BOOT CABEL BUT FAIL
Operation : Check / Read Info [ v1.10 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001600080000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
Configure emi settings
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect failed! Send report to support!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND/eMMC init Mode
Done!
Elapsed: 00:00:45
Reconnect Power/Cable! |
