Old 09-01-2009, 17:46   #1 (permalink)
Member: 710426
IMEI 351695019898826 cannot change
IMEI 351695019898826 is blocked at Pakistan and mobile default IMEI is not blocked but after format IMEI change to 351695019898826 and I try to restore back and it success but after 1 day it restore back to 351695019898826 again. I try to format again but it failed
Here is IMEI change log:
Action: imei
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: HEXING26_08B_GEMINI_HW
Software version: MAUI.08B.W09.08.MP.V
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 351695019898826
imei write method: mode-1
imei write channel: imei #2 for dual sim/mono CPU
new imei: 350448011234561
verification Ok
Finished, time used: 7 sec
Power off phone now !
Action: imei
Connecting, wait...
imei write channel: imei #1 for dual sim/mono CPU
new imei: 350448011234579
verification Ok
Finished, time used: 5 sec
and Here is error log
==== log: [31/8/2009 4:34:34 AM] ====
COM9 [VCP0] selected
module v2.89
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:BCE2:5833
status: FF
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [standard] generation
New firmware detected (v.2.89, database date: 15.08.2009):
HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info protocol ver: 05
ver. sw 1: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN
ver. sw 2: MAUI.08B.W09.08.MP.V2, 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
error: no any expected answer
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2__ffs...
warning: wrong data size at 0x00E25000, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
aborted by user
error: no any expected answer : wrong answer after chip id request
error: no any expected answer : wrong answer after chip cfi request
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
error: erase: can't detect chip at required chip base
Finalization Fail
Finished, time used: 239 sec
Remove/Install battery now !
Please post solution as soon as possible.
Old 09-02-2009, 07:46   #2 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
@public420
tray to write with method 1 phone must be fully power on after press on-off button
if still no luck
read full flash send at [email protected]
i know teem will help you
wbr.DYNET
Old 09-02-2009, 08:25   #3 (permalink)
R3İS's Avatar
Member: 1058593
Sonork: 100.1625725
Thanks Meter: 433
select imei#1(default imei inside firmware) and write new imei.after format your phone with complete mode operation is ok
Old 09-02-2009, 12:31   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
make full backup for emergency case and then
try to flash phone with available on support flash file.
check phone behavior with new firmware
Kisen F350 Dual Sim 2nd Imei cannot change md3862 Infinity-Box 13 05-02-2009 23:46
Cannot change IMEI on e770 prince4world Trident/AGERE Platform 0 09-25-2008 03:13
8120 cannot change imei VIZER Cruiser Suite 0 03-26-2006 13:47
x600 cannot change imei servtelgsm SYSOL Platform 1 01-21-2005 11:53
j70 cannot change imei bady97404 Sony 2 09-22-2003 11:24
Page generated in 0.31824 seconds with 9 queries
