imei alcatel ot 708A COM10 [VCP0] selected modulo v3.23 Servicio: Alcatel-708X, 708A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "repair imei" Nuevo imei: 350443038159743 ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 xxxxxxxxxxxxxxxxxx status: 01 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 98006F00000004:09EA0000000000 Flash AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.E7 E1D26C.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_901BF1F0].rpl rom info detection finished device-id: E7E1D26C rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, F0F11B90 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished Estado sim-lock: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished Estado sim-lock: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Imei original: 01194600619576 Flash 98006F00000004:09EA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... .................... pass #1 firmware remap[03]: 08000000 ..... pass #2 firmware remap[03]: 08000000 .................................................. ..................... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir imei Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: SN16Q050 Personalización SN16Q050 error: can't calculate security area (sec info, part #2), existing data will be used Check support area for updates ! security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: SN16Q050 Personalización SN16Q050 error: can't calculate security area (sec info, part #2), existing data will be used Check support area for updates ! security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done Escribir Done ====> Finalizado ... FFS formatting... Flash 98006F00000004:09EA0000000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_E7E1D26C_901BF1F0_20 100306-130626.B0X.bin Finalizado, tiempo usado: 7 min 26 sec Quite/coloque la bateria ahora ! |
Hi, As we can see, there is some problems with this operation for several firmware types. We will try to fix it and release updated software ASAP. |
Hello, Please, try to use this new software: http://www.infinity-box.com/download...e_v3.24_v1.rar Waiting for your results. |
