11-14-2014, 09:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: budaun Age: 38
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | IMEI failed 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : BU,FHNS>1-1 HW : BU,FHNS>1-5 SW : BU,FHNS>1-4 MM : BU,FHNS>1-2 VR : BU,FHNS>1-3 SN : BU,FHNS>1-6 Security Info : IMEI [1] : BU,FHNS>1-8 IMEI [2] : BU,FHNS>1-21 IMEI [3] : BU,FHNS>1-22 IMEI [4] : BU,FHNS>1-23 Read Ok! Update IMEI[1] to : 911317700042803 failed , record not exist or NVRAM damaged! Update IMEI[2] to : 911317700042811 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
11-14-2014, 09:45 | #2 (permalink) |
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x006E , [Micron] MT29F4G08ABC [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:04 Reconnect Power/Cable! |
11-14-2014, 16:30 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, seems as this phone require other method of IMEI repair. Will be in v1.09 or v1.10 , probably. |
The Following User Says Thank You to Dzirt For This Useful Post: |
