10-13-2015, 19:56 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Imei null Baseband unknown Samsung G900 clone(Help fix it) Code: Operation : Check / Read Info [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 51 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00C800BC009000550054007F007F0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009C , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00C8 00BC 0090 0055 0054 007F 007F [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! gifs upload Code: Operation : Fix Unknown BaseBand [ v1.33 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 51 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00C800BC009000550054007F007F0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009C , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00C8 00BC 0090 0055 0054 007F 007F [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok |
10-13-2015, 20:02 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. I will fix that in next version. CM2 made his work - sw clean all section in phone, which belongs to security. Now you need power on phone and check BB. If it still unknown - then need flash phone with good fw. |
10-13-2015, 20:39 | #3 (permalink) | |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
imei [IMG][/IMG] Here is Log wen I removed cable hang more than 10mis Code: Operation : Repair Security [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 51 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 357565765645677 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:06:31 Reconnect Power/Cable! | |
10-13-2015, 20:43 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Seems as this one phone is not supported yet for security repair. NAND updates for more operations will follow. |
