05-05-2016, 21:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | imei repaiar pb 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E43617264202877C4006042AB Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E43617264202877C4006042AB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E7400000 [eMMC] : FLASH_UCP : 3700 MiB [eMMC 4 GiB] DEV RID : EDE6A293072C9547C052F3ACF1FB2D23 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 358795258785529 IMEI [01] : 358968587565850 Set IMEI [00] : 354501384802426 Set IMEI [01] : 354501384802822 Prepare finished. Security check required! Wait for phone... Phone found! [ 36 ] Sync... Repair done! Done! Elapsed: 00:00:56 Reconnect Power/Cable! THANKS |
05-06-2016, 19:38 | #3 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hi, First do full reset then check if baseband ok repair again still same once repair bb still same then write good nvm then try hope ur prblm will solve Sent from my S_plus using Tapatalk |
05-07-2016, 07:50 | #5 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hi, Just Press Fix BB In CM2,, if still not solve go support and check there for same cpu nv ram aftr nv also ur prblm not solve once write FW if still not then check Hw |
05-07-2016, 08:07 | #6 (permalink) | |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Quote:
Operation : Fix Unknown BaseBand [ v1.47 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Its fix bb log | |
05-07-2016, 10:20 | #8 (permalink) | |
Also evry time this error is there solution Last edited by TUN10; 05-07-2016 at 10:28. | |
05-14-2016, 11:36 | #9 (permalink) |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | and another phone imei pb can't solve Start at : [5/14/2016 / 2:32:48 PM] Operation : Repair Security [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001EA498C8A623F Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001EA498C8A623F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 2F3DBD479859C7EAE78572E925E4F6E1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! WHO CAN HELP ME |
05-14-2016, 11:51 | #11 (permalink) |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Thanks fore quiq answare Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001EA498C8A623F Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001EA498C8A623F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 2F3DBD479859C7EAE78572E925E4F6E1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : rtech72_we_72_kk ProdModel : G9200 Device : rtech72_we_72_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n EXTRA : LCD [0] : hx8389c_qhd_dsi_vdo LCD [1] : ILI9807_dsi_vdo LCD [2] : rm68191_qhd_dsi_vdo LCD [3] : otm9605a_qhd_dsi_video LCD [4] : otm9608_qhd_dsi_cmd LCD [5] : nt35517_qhd_dsi_vdo#nt35517_qhd_dsi_vdo_xt LCD [6] : nt35516_dsi_cmd_qhd LCD [7] : hx8389b_qhd_dsi_vdo_xl_boe LCD [8] : hx8389b_qhd_dsi_vdo_xl_hsd LCD Res : 960#800x540#480 TOUCH [0] : GT9157 TOUCH [1] : ft6x36 TOUCH [2] : GT9XX TOUCH [3] : GT9158 TOUCH [4] : GT970#GT9XX TOUCH [5] : GT9158 CAM [0] : ov5645_pip_yuv CAM [1] : ov7695_yuv gs5604mipi_yuv gc0310mipi_yuv bf3a20_mipi_yuv gc2145mipi_yuv s5k4ecgx_mipi_yuv CAM [2] : hi258_mipi_yuv CAM [3] : hi704_yuv CAM [4] : ov5645_mipi_yuv CAM [5] : gc2035mipi_yuv CAM [6] : gc0329_yuv CAM [7] : s5k5eayx_yuv MODEM : P725_hspa_band_1_2_5_gps_co_clock_150318 LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB fa_IR hi_IN sk_SK sl_SI Done! Elapsed: 00:00:09 Reconnect Power/Cable! And also basband name have writen only ANDROID may be bb pb also have this phone.I have repaiar bb its the same Operation : Fix Unknown BaseBand [ v1.47 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001EA498C8A623F Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001EA498C8A623F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 2F3DBD479859C7EAE78572E925E4F6E1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Step #3 Step #3 ... Ok Reset Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
