Old 06-18-2016, 16:41   #1 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 655
imei repair done with errors
gioenee sl5.5
Operation : Repair Security [ v1.49 ]
Wait for phone...
Phone found! [ 82 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6752
BB_CPU_NME : [MediaTek] MT6732|MT6752_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8F
NAND Flash : NOT INSTALLED
eMMC Flash : 150100523832314D42000B18CA6C3293
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D42000B18CA6C3293
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x20776BF577E31F4D5DE5F8CAD213F7FC
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 35xxxxxxxxxxxx
Set IMEI [01] : 35xxxxxxxxxxxx
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 82 ]
Sync...
Device boot not done
Check Drivers
Try again
Error while post-checking procedure! Check drivers and battery charge!
In some cases - need reconnect mobile (just re-insert cable) on this step
Reconnect Power/Cable!
imei is repaired but after hard reset comes invalid
all drivers are installed windows 7 32bit
PLEASE SIR JAYDI FIX THIS ERROR
Old 06-18-2016, 18:00   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,543
Hello.
I can't fix it until you not provide me VID/PID of device, which device manager will find on second step ( after reconnect phone ).
Page generated in 0.19873 seconds with 7 queries
