04-13-2008, 06:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india ( Gujarat )
Member: 370998 Status: Offline Sonork: 100.1582579 Thanks Meter: 219 | Infinity Support with problem of restarting with sim inserted i had formmatt with infinity chinese miracle v2.37 after formatt phone is dead here is log Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6CAC:E3A7 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4221152D.[E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN_D6B615EE].rpl identification#1 detection finished device-id: 4221152D identification#1 protocol ver: 04 ver. sw1: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN ver. sw2: E553_K10F8.00.0, 11EA4929 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _4221152D_E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN _D6B615EE_20080412-123136.B0X.bin Finished, time used: 134 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! phone cant power on ( pressed long for 2 min ) as per log its says File system has modified Phone is Dead NOW I HAVE DOWNLOADED EPPROM AND FIRMWARE FROM SUPPORT E553_K10F8_E553_GPRS_MT6226_S01.00_0_ffs_01.B0E E553_K10F8_E553_GPRS_MT6226_S01.00_0_16m_En_Ru_Fr_ Es_De_Th_Vn_Tr_Ar.B0M And try to flash but cant succed here is log ==== log opened: [4/13/2008 10:01:49 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.37 S/N: 04F9:010E Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... E553_K10F8_E553_GPRS_MT6226_S01.00_0_ffs_01.B0E.bi n loaded detecting languages... Languages: not detected Loading file v.02... E553_K10F8_E553_GPRS_MT6226_S01.00_0_16m_En_Ru_Fr_ Es_De_Th_Vn_Tr_Ar.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN ver. sw2: E553_K10F8.00.0, 11EA4929 You have loaded file with security features enabled. detecting languages... Languages: En Ru Fr Es De Th Vn Tr Ar Loading file v.02... E553_K10F8_E553_GPRS_MT6226_S01.00_0_ffs_01.B0E.bi n loaded COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 11 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 14 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 21 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6CAC:E3A7 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80413-101132.B0E.bin flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done Area: Firmware flash: EC257E25082501:FFFFFF00000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 462 sec Remove/Install battery now ! COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6CAC:E3A7 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80413-101958.B0E.bin flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done Area: Firmware flash: EC257E25082501:FFFFFF00000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 2E3B3B3BFC2E3B3B3BFC2E3B3B3B332E3B3B3BE72E3B3B3BFC 2E3B3B3BFC2E3B3B3B2C2E3B3B3B502E3B3B3B482E3B3B3B7A 2E3B3B3B1C1A2E3B3B3B7A2E3B3B3BE42E3B3B3BFA1A1A8BC8 EC6658 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 427 sec Remove/Install battery now ! PLEASE HELP ME WHAT TO DO? THIS IS 1st PHONE ANOTHER PHONE 'S DISPLAY IS BLANK AFTER FORMATT BOTH R SAME PHONE SAME FIRMWARE |
04-13-2008, 07:41 | #3 (permalink) |
Member: 370998 Status: Offline Sonork: 100.1582579 Thanks Meter: 219 | Poblem Solved NO NEED TO WORRY INFINITY BOTH PHONE SUCCESFULLY REPAIRED COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1CA6:C255 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.C28A151A.[E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN_D6B615EE].rpl identification#1 detection finished device-id: C28A151A identification#1 protocol ver: 04 ver. sw1: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN ver. sw2: E553_K10F8.00.0, 11EA4929 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN]_20080413-115918.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _C28A151A_E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN _D6B615EE_20080413-115927.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:29EA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _C28A151A_E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN _D6B615EE_20080413-120233.B0X.bin Finished, time used: 422 sec Remove/Install battery now ! COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1CA6:C255 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E553_K10F8.00.0_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 13579024681122 connection Ok building list... done items total: 202 items to clear: 202 182 of 202 items cleared building list... done items remains: 1 Finished, time used: 217 sec Remove/Install battery now ! AND AFTER FLASH FORMATT FFS DONE THANKS |
04-13-2008, 10:00 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Chandreshswami If phone could not be flashed first time I think you have a reason to reball flash chip, it may be hardware damage too. |
to infinity support , pls we need alcatel 203ex simfree file in support | segun4u | Infinity-Box | 21 | 11-22-2009 14:33 |
infinity supporter , please support beyond b510 ??? | mantok | Infinity-Box | 3 | 08-27-2009 06:40 |
.:::::kg275 blinks after flash with infinity help infinity support ::::::. | SAMEER TAHIR | Infinity-Box | 1 | 09-16-2008 20:58 |
To Infinity-teem ;what Infinity Supported This Cpu | DYNET | Infinity-Box | 7 | 11-21-2007 09:38 |
infinity support can u hellp me for infinity box | mehdi_naghous | Infinity-Box | 2 | 06-04-2006 10:02 |
