04-12-2008, 09:03 | #1 (permalink) |
Registered User Join Date: Nov 2007
Member: 625970 Status: Offline Thanks Meter: 6 | imie has change is ther any way to repaire this?i tried reset to default but doesnt help and when entered sim it sayssim bloque COM4 [VCP1] selected Device: ZTE-A35 Checking data, wait... Action: unlock Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-132810.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\za35_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-132814.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-132822.B1E.bin reading [eeprom-dyn]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_20080412-132827.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 48 sec |
04-12-2008, 10:17 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, it was no any reason to write eeprom from support area in your phone. Now you must find your phone original eeprom file and write it back. |
04-12-2008, 10:40 | #3 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | Try writing this back to your phone.. Quote:
what's the problem with your phone? Last edited by kasamiko; 04-12-2008 at 10:50. | |
04-12-2008, 12:33 | #4 (permalink) |
Member: 625970 Status: Offline Thanks Meter: 6 | thank you very much for your help i write that file because of counter blocked now i am little confuse which is my original eepom file can you please guild me how to find the eeprom file, i did two the imeie is same start with 00499...... Device: ZTE-A35 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080403-171945.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\za35_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-165423.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-165431.B1E.bin reading [eeprom-dyn]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_20080412-165439.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 48 sec |
04-12-2008, 13:09 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | eeprom file example: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-165431.B1E.bin 20080412: date 2008-04-12 165431: time = 16:54 |
s319x unlocked imie have changed phone bloked now i cant find imie option | observer123 | Infinity-Box | 1 | 09-29-2009 11:03 |
There is STILL no UPDATE or support server has change address ?? | jode | Redbox | 4 | 10-27-2006 20:52 |
