Old 01-10-2007, 17:39   #1 (permalink)
Member: 130995
Thanks Meter: 35,227
* IMPORTANT * C257, C261, V175-V177 Unlock, Repair
Respected Infinity-Box users,
Due to huge amount of double posts in old subj related threads and total users ignorance of any advice to read old threads, here we collect most important information about C257, C261, V175, V176, V177 unlocking and repair.
Old threads located here:
C257, C261, V175, V176, V177 Information, Unlock, Reloaded, part #3
C257, C261, V175, V176, V177 Information, Unlock, Reloaded, part #2
C257, C261, V175, V176, V177 Information, Unlock, Reloaded, part #1
c261 problem
UPDATE 22 May 2006: C257, C261, V175, V176, V177, C115i sp-unlock
Most important manuals attached, please, read it before ask. If you don't see attached files or can't download it: login in forum before download.
More manuals available in www.infinity-box.com support area.
Known problems: as you know, currently not possible to unlock some C257, C261, V175, V176, V177.
If during unlock process you see in software log window error messages like:
"Err: this hardware not supported yet"
"Err: this unit can't be unlocked"
this means:
.currently we have no methods to unlock this phone.
.you can't unlock this phone with Infinity-Box.
.we can't give any advice how to unlock this phone.
.you can't unlock phone at the moment.
.такой телефон пока не разлачивается. Не надо спрашивать "когда".
Please, no need to ask us "when", "how long need to wait", no need to send to us backup files from phones that can't be unlocked. Backup from sp-locked phone can't help us to unlock it.
Please, no need to send to us sp-locked phones that can't be unlocked. This not helps to make solution.
Please, don't ask us privately to unlock phones that can't be unlocked. We will ignore all this kind of questions.
Unlock result (success or failure) depends on the next things:
.not depends on phone Firmware version
.not depends on phone Language Pack version
.not depends on phone Flex version
.not depends on network operator that phone is locked
.depends on your luck only
If you can't find required special Flex file in support area:
find original phone locked to the same network, read flash from it, send it to [email protected] and we will prepare special Flex file to repair your phone.
DON'T send me any flash backup from damaged phone !
If your phone can't Power-On (dead) or can't connect with software (dead):
1. Please, check battery voltage or check battery on other phone.
2. If battery Ok (and you know for sure that battery Ok): flash phone with Firmware + Flex + LP
3. If phone still can't Power On (dead): check phone hardware
4. If phone in "restart" condition: make repair procedure according to attached manual (also available in http://www.infinity-box.com support area)
TracFone customized phones: instruction attached.
For people who don't like to read manuals but want to see phones alive:
. Never flash sp-locked phones with any Flex files !
. It's no need to write any flex file in phone before unlock !
. Read unlock manual carefully and follow it exactly step-by-step !
If nothing helps, please, read about flowers and berries :
http://forum.gsmhosting.com/vbb/show...03&postcount=6
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 01-11-2007, 14:10   #2 (permalink)
SALIMUS's Avatar
Member: 54116
Thanks Meter: 218
very expecitly now ,
when the phone in not supported , no need to unlock; just wait new update
thank you for this explains
Old 01-12-2007, 19:33   #3 (permalink)
Masud-GSM's Avatar
Member: 396988
Sonork: 100.1613227
Thanks Meter: 182
Thank you for new update .............................
Old 01-12-2007, 22:05   #4 (permalink)
Member: 191257
c261 problem
this means:
the series of c261 makes resett after unlock.i tried all the flex which you add to the side but it is the same. i hope this will solve the problem. Thanks
Old 01-16-2007, 11:41   #5 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 199
Red face Help C261
Hi I Have Got Une Unlocked Phone C261 With Restart Problem I Flashed It With Locked Flex But Now Phone Is Working But Locked. Saoftware Says It Cannot Be Unlovked Pls Help
Old 01-16-2007, 12:15   #6 (permalink)
Member: 130995
If you don't have original eepron backup this means that now you have sp-locked phone.
if you have eeprom backup: just write it back
Old 01-18-2007, 06:09   #7 (permalink)
Member: 352329
Thanks Meter: 38
brother ,
i tried this all method but,
my C261 still same problem.[re-start with TRACFONE logo]
so how can i repair my C261
please help me brother
Old 01-18-2007, 06:23   #8 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
Originally Posted by chamin View Post
brother ,
try format ffs it should help you try
Old 01-19-2007, 11:46   #9 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
what meaning this "Phone is hacked : 68" V177 when I on phone display show me this... any idea...
Old 01-19-2007, 11:58   #10 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
COM2 selected
"smart write" active
Action: flash
Skip: Firmware
Write: Flex
Skip: Language Pack
Skip: Eeprom
Device: V175,V176,V177
Checking data, wait...
Connect...
Press and HOLD Power button...
Connecting...
Release Power button !
Connect Fail
Finished, time used: 11 sec
i try every think same error....
Remove/Install battery now !
Old 01-19-2007, 13:33   #11 (permalink)
Member: 130995
Originally Posted by irfanamin2 View Post
COM2 selected
Action: flash
Skip: Firmware
Write: Flex
Skip: Language Pack
Skip: Eeprom
Connect...
Connecting...
Connect Fail
If phone can't connect it can be cable problem or phone hw problem.
Old 01-19-2007, 14:27   #12 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
i cange cable i flash complete but now phone restart...any idea
Old 01-19-2007, 15:32   #13 (permalink)
Member: 130995
yes... I have an idea...
1. main action: don't be lazy
2. additional action: read first message in current thread
Old 01-22-2007, 03:57   #14 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
Hi,
i trying to unlock C261 when connect the phone the box asking for the flex. ok.
i trying to find the flex according to this instruction http://www.infinity-box.com/download...p?id_file=1766
but i cannot locate this files
pls direct me
Old 01-22-2007, 08:25   #15 (permalink)
Member: 130995
Originally Posted by MPhoneClinic View Post
Hi,
pls direct me
Hello,
right direction:
3. if you will follow step-1 and step-2 you will find manual about C261/V177 unlocking.
* IMPORTANT * C257, C261, V175-V177 Unlock, Repair InfinitySupport Infinity-Box 20 07-07-2008 21:32
* IMPORTANT * C257, C261, V175-V177 Unlock, Repair InfinitySupport Infinity-Box 72 01-10-2007 17:42
C257, C261, V175-V177 Unlock, Repair InfinitySupport Infinity-Box 41 11-03-2006 06:25
..:: FREE ADDON: Motorola Compal Tool v1.0 - C257, C261, V175-V177 ::.. zulea Motorola P2K (USB-Smart) 75 08-30-2006 15:50
..:: FREE ADDON: Motorola Compal Tool v1.0 - C257, C261, V175-V177 ::.. zulea SonyEricsson (USB-Smart) 21 08-16-2006 13:13
Page generated in 0.36496 seconds with 10 queries
