05-13-2016, 09:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: INDIA
Member: 466182 Status: Offline Sonork: 100.1604458 Thanks Meter: 88 | Unable to write in Panasonic P55 Problem - IMEI invalid Log Code: Card found : S/N : 6D65FD19 , v0130 Chinese Miracle II [MTK module] v 1.47 Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4B0001154D565835446501426731A5D0 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX5 [eMMC] : FLASH_CID : 1501004B3558564D42016544D0A53167 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 678BDBD4BC325B3C4098F45CB9BE767E INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Panasonic ProdName : P55 ProdModel : Panasonic P55 Device : P55 AndroidVer: 4.4.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.KK1.MP5.V1.5 SECURITY : IMEI_SW [1] : 356536060282913 IMEI_SW [2] : 356536060735100 BTMAC Addr : 00166D253A3B WiFi MAC : 00166D253A3C MODEM : BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V47_1_3g_n EXTRA : LCD [0] : hx8394a01_dsi_ld_lg LCD [1] : hx8394a01_dsi_ys_lg LCD [2] : hx8394a01_6589_hd_dsi_boe LCD [3] : hx8394a01_dsi_ys_cmi LCD [4] : otm1283a_boe_auo LCD Res : 1280 #800x720 #480 TOUCH [0] : GT9XX CAM [0] : ov5648_mipi_raw CAM [1] : gc2235mipi_raw MODEM : yulong89_wet_kk_md1_hspa LOCALE : en_US en_GB en_IN hi_IN in_ID de_DE es_ES fr_FR it_IT pt_PT vi_VN ar_IL th_TH bn_IN ja_JP zh_CN zh_TW tl_PH fa_IR ur_PK nl_NL pl_PL tr_TR ru_RU uk_UA af_ZA sw_TZ zu_ZA fr_BE nl_BE hdpi mdpi Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Repair Security [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4B0001154D565835446501426731A5D0 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX5 [eMMC] : FLASH_CID : 1501004B3558564D42016544D0A53167 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 678BDBD4BC325B3C4098F45CB9BE767E INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 356536060282913 IMEI [01] : 356536060735100 Set IMEI [00] : 356536060282913 Set IMEI [01] : 356536060735100 Prepare finished. Security check required! Wait for phone... Phone found! [ 33 ] Sync... Repair done! Done! Elapsed: 00:00:46 Reconnect Power/Cable! Baseband is ok. |
05-14-2016, 08:45 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Write NVRAM and try to repair again. Also format phone, switch on, use it for 1-2 minutes and then try to repair again. Br. Infinity Box Support Team. |
