03-01-2010, 18:10 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: sri lanka Age: 44
Member: 700923 Status: Offline Thanks Meter: 13 | ineed file sigmatel fxd Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7D03:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #03 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #04 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #05 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #06 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #07 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 98005700000032:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.686ACC3B.[GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX816_E NG_4_03.BIN_5E947D7B].rpl rom info detection finished ==================== New firmware detected (v.3.09, database date: unknown): GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX816_E NG_4_03.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 686ACC3B rom info ver: 05 sw version: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX816_E NG_4_03.BIN project-id: DSX816_Eng_4_03, 7B7D945E code offset: 00000000 ffs offset/size [01]: 00760000/000A0000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00760000 standard ffs/eeprom offset confirmed: 00760000 detecting ffs/eeprom size... ffs/eeprom size: 000A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00760000-007FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX816_E NG_4_03__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GINWAVE25_08A_GEM INI_PCB01_GSM_MT6225_S00.DSX816_ENG_4_03__ffs_2010 0301-153306.B0E.bin flash: 98005700000032:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98005700000032:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX816_EN G_4_03__system_log_686ACC3B_5E947D7B_20100301-153941.B0X.bin Finished, time used: 8 min 39 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
need pinout sigmatel fxd 3600 | bassemzini | Infinity-Box | 0 | 03-29-2010 19:22 |
NEED flash file for sigmatel FXD s45... | sunamuni_1985 | Infinity-Box | 11 | 03-03-2010 22:50 |
sigmatel fxd 6100 need flash file????? | omkarvitekar | Infinity-Box | 2 | 11-10-2009 15:59 |
need sigmatel fxd T33i flash file. | shuaib_kashish | Infinity-Box | 10 | 09-12-2009 05:04 |
flash file of sigmatel fxd s45 | .:SARCAR:. | Chinese Models & Cloned Phones | 1 | 08-26-2009 12:15 |
