Old 07-02-2007, 06:02   #1 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@infinitiy cm_tool
@support
i have on hand n95 new release and want to know that is it supported by infinity or not
cable direction
_________________
/ 1 2 3 4 5 6 7 8 \
also needed pinout proper to check
Old 07-02-2007, 07:37   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
If phone cpu name like MT62xx this phone is supported. It's no need to ask "supported or not". Just read carefully software functions description and you will get all information very easy.
cable: check FAQ thread to get info how to find pinout.
Dont forget to post here pinout after you will find it.
Old 07-02-2007, 08:21   #3 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@infinity
ya it is =MT6226BA
GONE THROUGH FAQ [PLS HELP TO FIND PINOUT ]
CHARGING PIN IS
_________________
/ 1 2 3 4 5 6 7 8 \
3=5.5 V[+V]
4=5.5 V[+V]
8=GND
Old 07-03-2007, 06:18   #4 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
all other pinout checked but still no connection with box
cant make tx and rx
Old 07-03-2007, 11:03   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please disassemble phone and check PCB.
maybe you have test points there (marked tx. rx)
Old 07-03-2007, 13:56   #6 (permalink)
Temporary banned !!
Member: 148045
Thanks Meter: 17
hi if you tesy this pinout and not work so you have unknown cable so try this way ,that is from infinty team
How to find pinout for unknown model:
In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model:
1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location)
2. find Charge pins (it's optional step, just to save your time during future research)
3. find +Battery pins (it's optional step, just to save your time during future research)
4. connect cable Gnd to phone Gnd
5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone
6. if flash read procedure can start this means that pinout found Ok and you can make other operations
Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models"it's good idea to find correct pinout acording to above instruction and send found pinout information with full text from phone back label to [email protected]
Page generated in 0.12529 seconds with 9 queries
