05-28-2008, 16:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,425 | @ Infinity >>> with pinfinder of infinity on mtk cpu i have failed so i opened that phone and saw CPU its 7880 so i try to find pins with pinfinder with Infneon E gold its successed then i have read full flash with select Lg kg370 its was done so now i am sending to you for giving us support Br Faisal_Computer |
05-28-2008, 16:34 | #2 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,425 | here is some more info sorry for creating this thread i was read late thread on Chinese Miracle sub forum Phone Model : Trend T101 Cpu : 7880 Pinout info : e-gold (820000) -> result: Rx:11 Tx:12 Br Faisal_Computer |
05-28-2008, 16:40 | #3 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,425 | Application: D:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.44 Wait... Current model: LG KG375 Ready COM14 [VCP0] selected Device: LG KG375 Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Documents and Settings\Mano Billy\My Documents\backup_LG KG375_eeprom-sta_20080528-041005.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Documents and Settings\Mano Billy\My Documents\backup_LG KG375_eeprom-sec_20080528-041019.B1E.bin reading [eeprom-complete]... file saved: C:\Documents and Settings\Mano Billy\My Documents\backup_LG KG375_eeprom-complete_20080528-041029.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Documents and Settings\Mano Billy\My Documents\backup_LG KG375_flash_20080528-042319.B1X.bin completed Finished, Remove/Install battery now ! Time used: 962 sec Br Faisal_Computer |
05-29-2008, 06:32 | #6 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,425 | phone connector 1x18 and Can you tell me when you will give us Support ? if you have software and Want to Test then i have that mobile with User code Br Faisal_Computer |
05-29-2008, 13:00 | #7 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Please, keep phone with you for some more time, hope to give you software in several hours. | |
05-29-2008, 16:46 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Here is updated software: http://www.infinity-box.biz/download...na01_v1.48.rar Please, try to use it and let me know about results. |
05-31-2008, 08:18 | #11 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,425 | here is Test Report , i have still mobile in hand , if you can want to more test i am here with thanks ==== log opened: [5/31/2008 12:12:02 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.48 Wait... Current model: Avvio-103A Ready Current model: LG KG375 COM14 ready COM14 [VCP0] selected Device: LG KG375 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-sta_20080531-121303.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-sec_20080531-121309.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-complete_20080531-121316.B1E.bin backup critical area Done Check memory... loading data... data loaded error: can't read codes Finished, Remove/Install battery now ! Time used: 31 sec WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM14 [VCP0] selected Device: LG KG375 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 26 sec WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM14 [VCP0] selected Device: LG KG375 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-sta_20080531-121441.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-sec_20080531-121449.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-complete_20080531-121456.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... error: set erase range error: set erase range error: reset failed Write Failed Finished, Remove/Install battery now ! Time used: 48 sec COM14 [VCP0] selected Device: LG KG375 Checking data, wait... Action: unlock direct unlock method #1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-sta_20080531-121550.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-sec_20080531-121554.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\LG KG375_eeprom-complete_20080531-121601.B1E.bin backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded Check memory Done Write... Erasing: eeprom-sta error: set erase range error: erase failed: 00FF8000 Write Failed Finished, Remove/Install battery now ! Time used: 37 sec Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Fail Finished Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: ERROR imei: ERROR Done Finished Br Faisal_Computer |
05-31-2008, 12:58 | #13 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,425 | oh !! sorry i was not seen !! here is test report COM14 [VCP0] selected Device: Trend-T101 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-sta_20080531-165123.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-sec_20080531-165128.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-complete_20080531-165135.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 29 sec Successfully unlock user code Br Faisal_Computer |
