03-21-2016, 21:36 | #1 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 853097 Status: Offline Sonork: 100.1622287 Thanks Meter: 131 | Can't Reset FRP Asus Z00VD MT6580 I realy need this solution I try to unlock bootloader via fastboot mode but always failed, maybe not checked allow oem unlock on setting I hope and I believe infinity team can support in next update Thank You |
The Following User Says Thank You to .::GEANECIV::. For This Useful Post: |
03-28-2016, 10:04 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: indonesia Age: 40
Member: 447517 Status: Offline Thanks Meter: 22 | Wait for phone... Phone found! [ 132 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505075B94C9CF5233 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x08000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2008 DA_LOAD_FAILED Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! |
07-25-2016, 11:36 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | ASUS secured support planned in some of near version. I got all samples and work on them. |
07-22-2017, 14:51 | #10 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | [QUOTE=JayDi;12604433]Make JUST frp reset. it is done thanx.. booting with vol down... Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 46 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A484147326505078DD19D2732BF Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A484147326505078DD19D2732BF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x46E20CEA4F0F5F235F71E3306D4F2B80 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to LoveLess For This Useful Post: |
07-25-2017, 09:44 | #11 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | same problem here 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 93 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
The Following User Says Thank You to SR9 For This Useful Post: |
07-25-2017, 11:35 | #12 (permalink) | |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Quote:
But His Also Support Others boxes. Like Miracle.Inferno ETC......... | |
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post: |
