01-03-2010, 16:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | G'five phone lock code problem ==== log: [12/4/2009 8:08:40 AM] ==== COM7 [VCP0] selected module v3.02 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F3CE:48F8 status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 38 sec Remove/Install battery now ! === log: [12/4/2009 8:09:33 AM] ==== COM7 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F3CE:48F8 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: A310_PCB01_GPRS_MT6226_S01.SW_V00_02_JIEERWANG.BIN ver. sw 2: A310.SW.V00.02.JIEERWANG, 00000000 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ........................ detect standard ffs/eeprom location pass #1... .................................................. ...... detect extended ffs/eeprom location pass #1... .............................................. detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: A310_PCB01_GPRS_MT6226_S01.SW_V00_02_JIEERWANG__ff s... file saved: C:\Program Files\InfinityBox\ChineseMiracle\A310_PCB01_GPRS_M T6226_S01.SW_V00_02_JIEERWANG__ffs_20091204-081612.B0E.bin flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:2BEA0000000000 Write: eeprom Write Done ====> Finalization ... Finalization Done Finished, time used: 517 sec Remove/Install battery now ! |
China Phone Lock Code Problem | zahidnawaz | Infinity-Box | 11 | 06-11-2009 20:32 |
K330 Phone Lock code problem- | PASSIONATE_BOYS | Infinity-Box | 5 | 05-26-2009 16:02 |
MyPhone T22 phone lock code problem | lezwire | Chinese Cocktail | 1 | 01-03-2008 07:12 |
w810i phone lock code problem | gaspardiana | Sony Ericsson | 7 | 12-19-2007 18:01 |
T68i PHONE LOCK CODE PROBLEM PLEASE HELP | axilleask | Sony Ericsson | 0 | 12-21-2004 16:51 |
