06-18-2017, 11:37 | #16 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
06-18-2017, 11:38 | #17 (permalink) | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
06-18-2017, 13:46 | #19 (permalink) | |
Power on phone, wait for boot. When device show Language Select screen - power it off, select factory mode, enabled adb, reboot and reset FRP. Reboot phone one more time. What a result? | |
06-18-2017, 14:19 | #20 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | Quote:
This issue on this devices have radio off and not signal always at send call warns that remove flight mode. | |
06-18-2017, 14:20 | #21 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 210 | Motorola Moto G5 Plus XT1686 FRP remove don Operation : Identify [ v1.0 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8953 CID : 0x0032 IMEI : 351892082787370 UID : 0B4A788100000000000000000000 Model Info ============ DevModel : XT1686 IntName : potter SW Info ============ DevSWVer : Blur_Version.25.31.75.potter.retail.en.US DevQCVer : LA.UM.5.6.r1-01900-89xx.0 BaseBand : M8953_12.18.07.19R POTTER_INDIADSDS_CUST BootLDRv : moto-msm8953-C0.89 HW Info ============ eMMCInfo : 32GB SAMSUNG RX14MB RV=08 PV=07 FV=0000000000000007 DRAMInfo : 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=5F Lock Info ============ WarrantyVoid : no FRP Lock : protected (75) Operation : Enable ADB (Moto) [ v1.0 ] Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1686 VerInfo : POTTER_INDIADSDS_CUST Version : Blur_Version.25.31.75.potter.retail.en.US Enabling ADB ... 1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON' 2. Select 'FACTORY MODE' and press 'POWER ON'! 3. Wait for device boot completely! Done! Elapsed: 00:00:25 Operation : Reset FRP (ADB) [ v1.0 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : potter_n Model : Moto G (5) Plus FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:09 |
The Following User Says Thank You to Bimal Shah For This Useful Post: |
06-18-2017, 15:17 | #22 (permalink) |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | I make factory reset . but result is same. then i put this cmd command (adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1). now problem solved. |
06-18-2017, 18:38 | #23 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Then it mean you had ADB running during work with AST. Will enable checking for running adb to avoid issues. |
06-18-2017, 22:21 | #24 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
Add Some More Features (Basic) Like Fix Bootloader Unlock Warning.... Enable Diag. Read Token/Send Unlock BL Code /Relock BL... Reboot To Various Mode (ADB/Bootloader) ... Flash File Verify Before Flash (If Not Enabled) To Avoid Downgrade. Repair Security... Step By Step As I Know New Module Project In Initial Stage.... | |
06-19-2017, 21:51 | #28 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Mexico
Member: 527046 Status: Offline Thanks Meter: 97 | Samsung SM-T280 FRP done Quote:
