06-28-2017, 15:40 | #61 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India
Member: 173081 Status: Offline Thanks Meter: 352 | vivo 1713 frp done Operation : Reset FRP (ADB) [ v1.0 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : 1601 Model : vivo 1713 FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:25 Regards Ajay Gupta |
The Following 3 Users Say Thank You to ajaystarin For This Useful Post: |
06-29-2017, 10:17 | #62 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Moto XT1022 done Code: Operation : Identify [ v1.0 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8210 CS CID : 0x0007 IMEI : UID : 5F259D0312000000000000000000 Model Info ============ DevModel : XT1022 IntName : condor SW Info ============ DevSWVer : Blur_Version.21.12.40.condor_retaildsds.retaildsdsall.en.03 DevQCVer : AU_LINUX_ANDROID_LNX.LA.3.5.1_RB1.04.04.02.048.020 BootLDRv : 5009 HW Info ============ eMMCInfo : 4GB Hynix REV=06 PRV=05 TYPE=17 DRAMInfo : 1024MB Hynix S4 SDRAM DIE=4Gb Lock Info ============ BLUnlock : no WarrantyVoid : no Done! Elapsed: 00:00:03 Code: Operation : Reset Settings [ v1.0 ] Mode : Format FS Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Block [1] ERASE OK! Block [2] ERASE OK! Done! Elapsed: 00:00:06 Code: Load from : F:\4\Moto Flasher\XT1022_CONDOR_RETAILDSDS_5.1_LPC23.13-34.2_cid7_CFC.xml.zip BUILD REQUEST INFO: SW Version: condor_retaildsds-user 5.1 LPC23.13-34.2 2 release-keysMSM8610BP_18033.4614.45.00R MBM Version: 50.0E Modem Version: MSM8610BP_18033.4614.45.00R FSG Version: MSM8610BP_FSG_01.52.00R Build Fingerprint: motorola/condor_retaildsds/condor_umtsds:5.1/LPC23.13-34.2/2:user/release-keys VERSION INFO FOUND UNDER 'ABOUT PHONE' SCREEN: System Version: 23.26.2.condor_retaildsds.retaildsdsall.en.03 Model number: Moto E Android Version: 5.1 Baseband Version: MSM8610BP_18033.4614.45.00R Build Number: LPC23.13-34.2 Build Date: Thu Jul 2 02:16:45 CDT 2015 ProgramDefinition files found! Loading bundle ... Load Ok! Operation : Flash [ v1.0 ] FlashFile : F:\4\Moto Flasher\XT1022_CONDOR_RETAILDSDS_5.1_LPC23.13-34.2_cid7_CFC.xml.zip Selected NormalFlash mode definition! Pre-Flash verification passed! Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Processing Flashing ... READ INFO : MAX-SPARSE-SIZE Result : 268435456 Executing OEM operation OEM operation OK! FLASH : PARTITION Unpack file, please wait ... FileInfo : gpt.bin , Checksum : 86a73274d21230be9c62a0349e20650b Sending data ... This may take a few seconds, if a different partition table is being flashed since we need to backup and restore a few partitions Flashing primary GPT image... Flashing backup GPT image... FLASH operation OK! FLASH : MOTOBOOT Unpack file, please wait ... FileInfo : motoboot.img , Checksum : 50fa4c2ef75bc4f8238d22ab176b9183 Sending data ... flashing tz ... flashing rpm ... flashing sdi ... flashing aboot ... flashing sbl1 ... FLASH operation OK! FLASH : LOGO Unpack file, please wait ... FileInfo : logo.bin , Checksum : 1c958756245ce98d8809d9950dfb919f Sending data ... FLASH operation OK! FLASH : BOOT Unpack file, please wait ... FileInfo : boot.img , Checksum : 43adea9765ca93622143c0b81028a193 Sending data ... FLASH operation OK! FLASH : RECOVERY Unpack file, please wait ... FileInfo : recovery.img , Checksum : 8b3cf5223fb4863b32a984cda75cf5c4 Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.0 , Checksum : 4d8447aa7c4508436b2dd68929443340 Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.1 , Checksum : 09282ca7c49dc900fbc65432ba85d3ba Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.2 , Checksum : c193c62052f3f6f9a3071579d2dfb503 Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.3 , Checksum : 96013b42b72d3e2b94d0b84c2f84b0aa Sending data ... FLASH operation OK! FLASH : MODEM Unpack file, please wait ... FileInfo : NON-HLOS.bin , Checksum : 593067b9026c623aecdb86a4fcf3ad22 Sending data ... FLASH operation OK! ERASE : MODEMST1 ERASE operation OK! ERASE : MODEMST2 ERASE operation OK! FLASH : FSG Unpack file, please wait ... FileInfo : fsg.mbn , Checksum : 212c6a2e416fe9beea03bde059985d50 Sending data ... FLASH operation OK! ERASE : CACHE ERASE operation OK! ERASE : USERDATA ERASE operation OK! Executing OEM operation OEM operation OK! Flashing finished! Done! Elapsed: 00:03:49 |
06-30-2017, 12:52 | #63 (permalink) |
Crazy Poster Join Date: Sep 2007
Member: 587029 Status: Offline Thanks Meter: 8 | moto tab mz609-32 to many attempts done Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Block [1] ERASE OK! Block [2] ERASE OK! |
The Following User Says Thank You to electrun_NG For This Useful Post: |
07-03-2017, 08:40 | #65 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | moto G4 xt1643 frp done but not remove. Operation : Reset FRP (ADB) [ v1.0 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : athene_f Model : Moto G (4) FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:15 but frp not done. any advice from my friends. thanks with best regards, mahir |
07-03-2017, 13:28 | #66 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 53
Member: 91140 Status: Offline Thanks Meter: 12 | Motorola Moto X Hello! I have a problem with FRP remove on Motorola Moto X (XT 1092) Operation : Enable ADB (Moto) [ v1.0 ] Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : iled to get property ro.boot.hardware.sku, err = 0, status = 1; Property ro.boot.hardware.sku not Please help! Thanks! |
07-04-2017, 10:50 | #68 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
07-04-2017, 17:39 | #70 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Poland Age: 47
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | Add pagination (-P) when flashing system.img otherwise will be errors like: Sending data ... Data size exceeds download buffer FAIL FLASH operation FAIL! to all others who killed motorola by flashing, [fastboot -P flash system system.img] should help |
07-05-2017, 10:23 | #71 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | XT 1562 format and Reset frp done Code: Operation : Identify [ v1.0 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8939 CID : 0x0007 IMEI : 358967066343581 UID : 3DB9870400000000000000000000 Model Info ============ DevModel : XT1562 IntName : lux SW Info ============ DevSWVer : Blur_Version.24.81.1.lux_retasia_ds.retasiaall.en.03 DevQCVer : AU_LINUX_ANDROID_LA.BR.1.1.3_RB1.05.01.00.032.015 BaseBand : M8936_2020632.44.03.21.57R LUX_EMEA_DSDS_CUST BootLDRv : moto-msm8939-80.EE HW Info ============ eMMCInfo : 16GB Toshiba REV=07 PRV=00 TYPE=57 DRAMInfo : 2048MB Elpida S8 SDRAM DIE=4Gb Lock Info ============ BLUnlock : no WarrantyVoid : no FRP Lock : protected (75) Done! Elapsed: 00:00:05 Code: Operation : Reset Settings [ v1.0 ] Mode : Format FS Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Block [1] ERASE OK! Block [2] ERASE OK! Done! Elapsed: 00:00:10 Code: Operation : Enable ADB (Moto) [ v1.0 ] Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1562 VerInfo : LUX_EMEA_DSDS_CUST Version : Blur_Version.24.81.1.lux_retasia_ds.retasiaall.en.03 Enabling ADB ... 1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON' 2. Select 'FACTORY MODE' and press 'POWER ON'! 3. Wait for device boot completely! Done! Elapsed: 00:00:10 Code: Operation : Reset FRP (ADB) [ v1.0 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : lux_retasia_ds Model : XT1562 FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:08 |
The Following User Says Thank You to princesaddam For This Useful Post: |
07-05-2017, 10:25 | #72 (permalink) |
07-05-2017, 10:28 | #73 (permalink) |
07-05-2017, 10:31 | #74 (permalink) |
07-05-2017, 10:34 | #75 (permalink) |
