07-26-2017, 07:54 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Infinity-Box Android Service Tool / AST v1.01 - first update Fastboot tab activated : - Identify / Read device info - Reset FRP ( MTK, SPRD, QLM mode ) - Change mode ( Normal, Bootloader, Recovery, EDL ) Motorola : - Improved Flashing engine In case of downgrade SW will ask about force flashing ( if bootloader unlocked ) Improved flashing : timeout fixes for big blocks Improved flashing : revised flash pre-verification Improved flashing : FW check and verify revised - Enabled Bootloader operations Get Unlock token - get data for Motorola boot unlock ( via MotoUnlockDev support ) Send unlock token - apply boot unlock code to device ( just copy received code in buffer ) - Improved ADB enable function - Improved Reset FRP function Other FastBoot/ADB protocols revised Some main core changes and bugfixes Download From here Index of pub/software/ |
The Following 5 Users Say Thank You to Momin_Telecom For This Useful Post: |
07-26-2017, 12:32 | #6 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
To run this software you need Infinity-Box Dongle. More info about it you can find here- https://www.infinity-box.com/ Br. Infinity Box Team. | |
08-12-2017, 20:13 | #7 (permalink) |
Junior Member Join Date: Jan 2016 Location: mexico
Member: 2516456 Status: Offline Sonork: iransalamanca Thanks Meter: 0 | for zte v8 se mt6755 frp?? i try whit cm2mtk, but it failed Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! |
