06-10-2018, 14:46 | #166 (permalink) |
Junior Member Join Date: Apr 2018 Location: Bogra, Bangladesh
Member: 2832893 Status: Offline Thanks Meter: 3 | ASUS_Z010D FRP done by enable ADB within few second Infinity-Box Android Service Tool [AST] v1.03 Operation : Reset FRP [ v1.03 ] Mode : Remove ASUS GENERIC FRP Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! ADB activated! - > Info : Wait till device boot, make offline setup until device show message about protection - > Info : Re-connect cable, make "FRP Reset" in ADB tab! Done! Elapsed: 00:00:06 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : WW_Phone Model : ASUS_Z010D FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:07 Thanks Team! |
The Following 2 Users Say Thank You to Arman01725 For This Useful Post: |
09-27-2018, 00:41 | #170 (permalink) |
Junior Member Join Date: Sep 2006 Location: UKR
Member: 346630 Status: Offline Thanks Meter: 9 | ASUS ZenPad Z10 (ZT500KL, Verizon exclusive) Operation : Reset FRP [ v1.03 ] Mode : Remove ASUS GENERIC FRP Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! ADB activated! - > Info : Wait till device boot, make offline setup until device show message about protection - > Info : Re-connect cable, make "FRP Reset" in ADB tab! Done! Elapsed: 00:00:16 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : VZW_P00I Model : P00I FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:30 |
The Following 2 Users Say Thank You to lamik For This Useful Post: |
12-05-2018, 07:08 | #175 (permalink) |
Junior Member Join Date: Dec 2005 Location: India
Member: 210639 Status: Offline Thanks Meter: 1 | Infinity-Box Android Service Tool [AST] v1.03 Operation : Reset FRP [ v1.03 ] Mode : Remove MTK GENERIC FRP Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! FRP Erase FAIL! Done! Elapsed: 00:00:20 Pls give me solution for this i am doing FRP for Mi 6A and it get fail everytime. |
12-05-2018, 09:08 | #177 (permalink) |
Member: 210639 Status: Offline Thanks Meter: 1 | Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 0766 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0xE7000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : Unknown Mode! Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Pls give solution for this error which i get when unlocking mi account of Mi 6A. Dear Infinity team please reply with solution to my posted problems and also guide me from where should i get the DA boot files thanks in advance. Last edited by YellowBoss; 12-18-2018 at 10:45. |
12-07-2018, 10:00 | #178 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Dear sir plz post in correct theard this is not Mtk theard,,plz use latest version of Mtk I.E 2.02 http://forum.gsmhosting.com/vbb/f296...ments-2509099/ | |
The Following User Says Thank You to princesaddam For This Useful Post: |
12-18-2018, 10:48 | #179 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,976 | Quote:
I just see your question about MTK here, Please to avoid delay with replies always use correct thread or create a new one. Also please always follow the instruction given by software ! Thank you ! | |
01-14-2019, 11:37 | #180 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,770 | Dear Infinity-Box Team, Please add FRP RESET for Android 7, 8.x.x & 9 in both fastboot & Adb mode in next update. Also add factory RESET button in adb tap Thanks in advance |
