11-25-2007, 10:44 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 46
Member: 115863 Status: Offline Thanks Meter: 8 | infinity-box can't detect its vcp port |
11-25-2007, 11:02 | #2 (permalink) | |
Please, re-install Infinity-Box drivers. if still no luck explain the problem so detailed as possible. | |
11-25-2007, 19:33 | #6 (permalink) | |
I don't understand what is the problem ? Is box detected by PC ? Is it detected as VCP port or as other device or not detected at all ? You must prepare so detailed explanation as possible, we can't give any advice you your problem just "something not work". | |
11-26-2007, 05:53 | #7 (permalink) |
Member: 115863 Status: Offline Thanks Meter: 8 | The box is detect by pc because it can open all the software and can enter to support area. but when I check the ports availability, It doesn't have virtual com port as usual. It only shows computer com1 and com2 it does not have the normal virtual com ports as I always use. I tried to uninstall and install, tried with 2 pc but same result. |
11-26-2007, 18:11 | #9 (permalink) | |
Also check other usb devices in Device Manager, probably box detected by PC not like VCP port but like FTxxxx usb device. | |
04-13-2010, 21:07 | #10 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 748621 Status: Offline Thanks Meter: 7 | I have the same problem I opened the virtual ports egate only infinity box and talk to my tent and shift the box and the other has the same problem that's probably the key problem need unlock alcatel 102a |
04-16-2010, 21:32 | #11 (permalink) | |
Could you, please, explain what is the problem exactly. What required devices exactly you can not find in Device Manager ? | |
10-01-2010, 10:55 | #15 (permalink) | |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | Quote:
reinstall your window then install infinity -box software. 100% solve your problem........... Br: Harkishan | |
Infinity pinfinder can't detect pinout and unlock phone | magucha | Infinity-Box | 7 | 12-10-2009 19:15 |
HELP SIROYA! Can't detect ULT Pro port | Johnybye | ULT PRO | 5 | 10-24-2008 16:21 |
Infinity Pinfinder can't Detect Need Help From Infinity | Aazib jhon | Infinity-Box | 11 | 07-14-2008 11:02 |
Does infinity box work with USB 1 port | etimoult | Infinity-Box | 7 | 06-04-2008 19:16 |
Infinity Box won't give a COM PORT ?!?! | 07heaven | Infinity-Box | 4 | 07-31-2007 10:04 |
