Old 07-09-2017, 12:10   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Infinity-Box Chinese Miracle-2 MTK/MediaTek : Supplementary files package for v1.58
- Boot package updated
- Ini updated, new devices are supported:
Original Nokia 3 phone ( Unique! )
Base Secure Phones
Huawei (TITx and similar)
Select "SP : Select model" and choose need mode/model
- Support package
Lot of new DRAM and eMMC config included
How to use:
- Just install files and you will see boot selection menu
How to install:
1. Download from support area installer InfinityBox_update_CM2MTK_Supplementary-files-package_v1.58.7z
2. Install it, you must select folder where you already have CM2MTK v1.58 instlled
More information:
- http://forum.gsmhosting.com/vbb/f296...ate-d-2241771/
- http://forum.gsmhosting.com/vbb/f296...urity-2241779/
The Following 69 Users Say Thank You to YellowBoss For This Useful Post:
Old 07-09-2017, 12:13   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Huawei Honor :
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 510001154D33313398600642CFE0819B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM313
[eMMC] : FLASH_CID : 150100513331334D420660989B8153CF
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0xB37B1BC738FA2892A9EAE4421896EBCD
INT RAM    : 0x00020000
EXT RAM    : 0x80000000 [2 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : HONOR
ProdName  : TIT-L01
ProdModel : TIT-L01
Device    : HWTIT-L6735
AndroidVer: 5.1
MTKxCPU   : MT6735
MTKxPRJ   : ALPS.L1.MP3.V2_ONTIM6735.66T.L1_P73
SECURITY :
IMEI_SW [1] : 861245031285835
IMEI_SW [2] : 861245036035839
BTMAC Addr  : 8013826E89F3
WiFi MAC    : 801382701093
MODEM :
BaseBand  : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P24_T2_1_lwg_1
EXTRA :
LCD : Not info available :(
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : ov13850OF_mipi_raw
CAM [1] : ov5670OF_mipi_raw
CAM [2] : ov13850QT_mipi_raw
CAM [3] : ov5670SE_mipi_raw
MODEM : mt6735_sp_lwg_dsds_c2kirat_prod mt6735_sp_lwg_dsds_c2kirat_prod2
LOCALE : zh_CN zh_HK zh_TW en_US en_GB
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 7586
Done!
Elapsed: 00:00:12
The Following 23 Users Say Thank You to JayDi For This Useful Post:
Old 07-09-2017, 12:21   #3 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
very good a smal pachage with a big suplement to mtk module without update very nice job team
The Following User Says Thank You to rebainoor For This Useful Post:
Old 07-09-2017, 12:32   #4 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
not working for us-----------
The Following 2 Users Say Thank You to kothamamun For This Useful Post:
Old 07-09-2017, 12:41   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
You must not put the files in proper place
Br - srinibas
The Following 3 Users Say Thank You to srinibas For This Useful Post:
Old 07-09-2017, 12:45   #6 (permalink)
JayDi's Avatar
Member: 462970
Br - srinibas
Now need just select folder in installer
Old 07-09-2017, 12:48   #7 (permalink)
Member: 704044
Thanks Meter: 212
Old supplimentry files have not worked for me
but new supplimentry exe from support works fine.
Thanks once again supporter
The Following User Says Thank You to sekarrajan For This Useful Post:
Old 07-09-2017, 12:50   #8 (permalink)
Member: 704044
Thanks Meter: 212
RUN THIS EXE AND SET INSTALLATION FOLDER FOR CM2 MTK
JOB DONE NOW RESTART CM2 MTK
Old 07-09-2017, 12:51   #9 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
Always simple and effective
Old 07-09-2017, 13:02   #10 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 225
infinity box best of the best
The Following User Says Thank You to afghanistanmob For This Useful Post:
Old 07-09-2017, 13:23   #11 (permalink)
localizator's Avatar
Member: 2550141
Thanks Meter: 1,115
How-To use Supplementary files package for CM2 MTK v1.58
Download:
Mega.nz
Gdrive
The Following 29 Users Say Thank You to localizator For This Useful Post:
Old 07-09-2017, 14:56   #12 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Not work for me , Badlucek
Old 07-09-2017, 15:08   #13 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
now working fine great team infinity but remember mtk new update coun/ down just little away
Old 07-10-2017, 04:11   #14 (permalink)
Member: 2346548
Thanks Meter: 36
good job but waitting for more support to secured boot devices
thanks , best regards
The Following User Says Thank You to shady_oscar For This Useful Post:
Old 07-10-2017, 05:44   #15 (permalink)
mamo_mogon03's Avatar
Member: 235905
Sonork: 100.1580742:mamomogon03
Thanks Meter: 145
Fix you AV please. It cannot removed virus. Thanks
The Following 3 Users Say Thank You to mamo_mogon03 For This Useful Post:
Page generated in 0.25103 seconds with 8 queries
