Old 04-04-2018, 07:01   #331 (permalink)
Member: 2814511
Thanks Meter: 51
lenovo A916 flash done by cm2...............
The Following User Says Thank You to gsmmim For This Useful Post:
Old 04-04-2018, 21:18   #332 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 70
https://media.giphy.com/media/o4LHcRDeiHims/giphy.gif
Old 04-04-2018, 21:19   #333 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 70
https://giphy.com/gifs/o4LHcRDeiHims/html5
Old 04-07-2018, 12:51   #334 (permalink)
Member: 2814511
Thanks Meter: 51
lenovo A2010a pattern lock done by cm2..........
The Following 2 Users Say Thank You to gsmmim For This Useful Post:
Old 04-09-2018, 08:30   #335 (permalink)
Member: 2814511
Thanks Meter: 51
lenovo k10a40 boot loder lock any boby help me
Old 04-09-2018, 14:48   #336 (permalink)
Member: 1677653
Thanks Meter: 2,769
Where is log from CM2?
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 04-14-2018, 13:22   #337 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
boot problem huawei cun-29
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[DA_ERROR] : Correct BOOT CONFIGURATION not found for target!
Try Re-Install CM2MTK module!
Boot Error!
Operation Failed
Elapsed: 00:00:03
Reconnect Power/Cable!
Old 04-18-2018, 08:34   #338 (permalink)
Member: 1117638
Sonork: G_ABBAS
Thanks Meter: 19
InfinityBox CM2MT2
http://dl1.infinity-box.com/download...M2MT2_v2.00.7z
Old 04-19-2018, 08:17   #339 (permalink)
Member: 2814511
Thanks Meter: 51
symphony V47 frp remove done by cm2........
Old 04-19-2018, 08:31   #340 (permalink)
Member: 1043909
Thanks Meter: 60,921
Originally Posted by G_ABBAS View Post
InfinityBox CM2MT2
please do not post direct links, all direct links will be expired soon
Old 04-19-2018, 08:41   #341 (permalink)
Member: 1043909
New version released - http://forum.gsmhosting.com/vbb/f296...tions-2386273/
Old 05-16-2018, 06:27   #342 (permalink)
Member: 2664255
Thanks Meter: 8
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : 004500DE009400930076005000080000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
DAgent sent , init HW now
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0053 , NAND_UNKNOWN
[NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008
[NAND] : FLASH_LEN : 0x200000000
[NAND] : FLASH_EXT : 4000/0100/00
DEV RID : 0x64F92899622C6077B822192CB411C165
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND Flash not supported yet!
Old 09-22-2019, 06:11   #343 (permalink)
Member: 2266425
Thanks Meter: 58
cm2 new mtk 6261 read flash done when write flash back then show bad file selected
Operation : Read Flash [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 4 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 399E046BED17A8F41975D6EA123F5E6A
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Reading Flash Content now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info : WH61D_11C_M123C_PCB01_gprs_MT6261_S00.MAUI_11C_W13 _52_MP_V2_F21.bin
FileVersion : MAUI.11C.W13.52.MP.V2.F21
[ScatCFG] : MT6261 / MAUI.11C.W13.52.MP.V2.F21 / NOR , SF
Firmware saved to : C:\InfinityBox\CM2MTK\Read_out\WH61D_11C_M123C_PCB 01_gprs_MT6261_S00\
Done!
Elapsed: 00:00:21
Load File
Bad file detected!
Old 09-22-2019, 09:45   #344 (permalink)
Member: 2266425
Thanks Meter: 58
cm2 mtk 6261 new cpu read flah ok then we write readed flash back cm2 says =bad file selected=== pls suport team solve this problem file like scter file mtk 6261 file info cfg
Page generated in 0.22217 seconds with 8 queries
