07-30-2017, 11:37 | #65 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | mobicel berry boot error when read firmware backup cm2 please update new cpu support. Software stuck on not responding that's way can't copy log check **** picture for log... Sent from my D5803 using Tapatalk |
07-30-2017, 11:44 | #66 (permalink) | |
Member: 2555393 Status: Offline Thanks Meter: 268 | Quote:
Great infinity cm2 feel the power... Sent from my D5803 using Tapatalk | |
07-30-2017, 11:56 | #68 (permalink) |
Member: 2555393 Status: Offline Thanks Meter: 268 | Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838454134010416EEB114B7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4AE8H [eMMC] : FLASH_CID : 700100454838454134010416EEB114B7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x020C5EFE00ADF0903305A8E2D9627BA5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Mobicel ProdName : BERRY ProdModel : BERRY Device : BERRY AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 [Read Ok] : preloader_v2600.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / v2600 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1838 MiB Scatter saved to : C:\Users\GUJJAR\Desktop\MT6580__Mobicel__BERRY__BE RRY__6.0__ALPS.W10.24.p0\ All done! Done! Elapsed: 00:11:59 Reconnect Power/Cable! Sent from my D5803 using Tapatalk |
The Following 3 Users Say Thank You to sajjad akram For This Useful Post: |
07-31-2017, 13:44 | #69 (permalink) | ||
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Nokia 3 FRP RESET DONE Quote:
The Following 3 Users Say Thank You to nahidroman For This Useful Post: |
08-03-2017, 11:21 | #70 (permalink) |
Freak Poster Join Date: Feb 2012 Location: Harare
Member: 1727968 Status: Offline Sonork: ngonie Thanks Meter: 42 | vodafone vdf 610 unlocking failed 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 200 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
08-04-2017, 01:16 | #71 (permalink) | |
No Life Poster Join Date: Sep 2011 Location: karachi
Member: 1655288 Status: Offline Thanks Meter: 90 | Quote:
08-06-2017, 10:35 | #72 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | oppo a1603 5.1 imei repair Done ===================== Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100463331324D4206B4BA90893377 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM213 [eMMC] : FLASH_CID : 150100463331324D4206B4BA90893377 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x148975AD58C79743C159CEB3EA38F4A8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok IMEI [00] : 8611xxxxxxxxxxx IMEI [01] : 8611xxxxxxxxxxx Set IMEI [00] : 352xxxxxxxxxxxxx Set IMEI [01] : 352xxxxxxxxxxxxx Prepare finished. Security check required! |
The Following 2 Users Say Thank You to mcclinic For This Useful Post: |
08-14-2017, 09:38 | #73 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2747388 Status: Offline Thanks Meter: 0 | Remove FRP on NOKIA 3 Hi guys I really, really need your help. I need to remove FRP on NOKIA 3 TA-1020. I downloaded Infinity box and installed it in my laptop. My laptop is running windows 10 Pro. The problem is that whenever I try to run Infinity box it does not open at all. I have uninstalled and reinstalled it but still it does not open. What am I missing here? is there an external drive that needs to be connected to my laptop that works with Infinity box? Is my Windows 10 Pro a problem... I really need your help guys. I would appreciate help from you guys Thank you |
08-14-2017, 10:30 | #74 (permalink) |
Insane Poster Join Date: Dec 2015
Member: 2507812 Status: Offline Thanks Meter: 6 | JayDi M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001A80000 Erase : 0x0000000001BC8000-0x0000000004000000 Erase : 0x0000000007000000-0x0000000000040000 Erase : 0x0000000007800000-0x0000000002C00000 Erase : 0x000000000A900000-0x0000000E83EFBE00 Flash Erase Done, time used : 00:00:06 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Ok Flash Partition : MD1IMG Image Flash Ok Flash Partition : MD1DSP Image Flash Ok Flash Partition : MD1ARM7 Image Flash Ok Flash Partition : MD3IMG Image Flash Ok Flash Partition : LK Image Flash Ok Flash Partition : LK2 Image Flash Ok Flash Partition : BOOT Image Flash Ok Flash Partition : LOGO Image Flash Ok Flash Partition : TEE1 Image Flash Ok Flash Partition : TEE2 Image Flash Ok Flash Partition : SECRO Image Flash Ok Flash Partition : SYSTEM Image Flash Failed! Failed to download all data! Check battery and cable! Operation Failed Elapsed: 00:03:47 Reconnect Power/Cable! Finish at : [8/13/2017 / 3:55:01 PM] |
08-16-2017, 03:56 | #75 (permalink) | |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Unlock done... with one click Quote:
The Following 3 Users Say Thank You to dyo For This Useful Post: |
