03-21-2017, 07:42 | #466 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2656348 Status: Offline Thanks Meter: 3 | me and my friends love using cm2 and we are waiting for mtk update. pls. make some update sir thanks |
03-25-2017, 16:14 | #469 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | Huawei cun-u29 5.1 bootloader unlocked show but not detect in identify ============================================ Operation : FastBoot : ReadInfo [ v1.58 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 43 ] Sync... Protocol : 0.5 Device : HQ6582_WE_B1B_L1 Storage : eMMC BootLoader : Unlocked Warranty : Tampered Secure : Disabled ExtraStat : FB Load Supported! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
03-25-2017, 16:24 | #470 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | Quote:
03-25-2017, 16:55 | #471 (permalink) |
Member: 593876 Status: Offline Thanks Meter: 302 | same result Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
03-25-2017, 17:08 | #472 (permalink) | |
or only - i tested on y5ii and y3ii Last edited by sky73; 03-25-2017 at 17:15. | |
03-26-2017, 12:44 | #475 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Lenovo VIBE FRP LOCK REMOVE Lenovo VIBE FRP LOCK REMOVE Code: Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332383CBD00424F0618CC Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332383CBD00424F0618CC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200BD3CCC18C24F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0166581590C01CBEF7E2CDDC8EB9F9BA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : P1ma40 ProdModel : Lenovo P1ma40 Device : P1ma40 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : P1ma40_USR_S025_1509241530_MP3V2_16G_ROW_US Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332383CBD00424F0618CC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200BD3CCC18C24F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0166581590C01CBEF7E2CDDC8EB9F9BA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! B.Uttam |
03-27-2017, 14:35 | #476 (permalink) |
Member: 1876736 Status: Offline Thanks Meter: 735 | request to add mezio m3 note Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00002006 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Last edited by sky73; 03-27-2017 at 14:44. |
03-30-2017, 11:43 | #477 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Poland Age: 44
Member: 87364 Status: Offline Thanks Meter: 63 | Asus ZenPad Model: P00C - please add this model. Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x97 NAND Flash : NOT INSTALLED eMMC Flash : 90014A484247346132A44D919E86436D Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBC000000 DRAM_INIT_REQ_FAILED Boot Error! Operation Failed Elapsed: 00:00:36 Reconnect Power/Cable! |
03-31-2017, 05:32 | #478 (permalink) |
Major Poster Join Date: Jan 2017 Location: Dhaka.BD
Member: 2667438 Status: Offline Sonork: 100.1676500 Thanks Meter: 34 | Why Infinity team stop update mtk & spd..we need mtk secure phone support & spd new cpu added..mtk update stop about 6month & spd 4month..give update soon..plz |
The Following 3 Users Say Thank You to SaddamHosainSD For This Useful Post: |
03-31-2017, 13:14 | #479 (permalink) | |
You are beginner with 7 posts. Please in future do not post nonsence but if you REALLY have a problem you should post problem details. You should post model name, operation log text and problem description but not only bla-bla. I am sure one day you will understand what is "good test report" means. Waiting for you REAL test reports ! | |
03-31-2017, 13:22 | #480 (permalink) | |
Please, when you will have new ideas and test reports - think well before write something. Thank you ! | |
