10-11-2016, 12:21 | #48 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | LeEco X620 not connect Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED SECURE_BOOT : DA_AUTH_REUIRED! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Code: Start at : [11.10.2016 / 9:14:02] Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 43G23 [eMMC] : FLASH_CID : 1101003033324733340042E2BA0E13FD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xBD017178EF1DB222BD0693C8EF1DB222 INT RAM : 0x00040000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : LeEco ProdName : Le2_CN1 ProdModel : Le X620 Device : le_x6 AndroidVer: 6.0 MTKxCPU : MT6797 MTKxPRJ : alps-mp-m0.mp9-V1.0.1_hq6797.6c.b1a.m_P2 EXTRA : LCD : Not info available :( LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : ov16880_mipi_raw CAM [1] : ov16880_primax_mipi_raw CAM [2] : imx230_mipi_raw CAM [3] : imx230_primax_mipi_raw CAM [4] : ov8865_mipi_raw CAM [5] : ov8865_sunny_mipi_raw MODEM : mt6797_sp_lwctg_mp2_umoly0020_prod LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:11 Reconnect Power/Cable! "Orange State Your device has been unlocked Your device will boot in 5 seconds" |
The Following User Says Thank You to Abzal For This Useful Post: |
10-11-2016, 12:27 | #49 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. There is in latest version that phone added in Models list - select LeEco. After you can make service/reset operations. Not all, but enough for FRP and rest. |
10-11-2016, 13:25 | #52 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | Yes Code: Card found : S/N : C5 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007024 SECURE_BOOT : DA_AUTH_REUIRED! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Code: Card found : S/N : C5 Chinese Miracle II [MTK module] v 1.56 Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 43G23 [eMMC] : FLASH_CID : 1101003033324733340042E2BA0E13FD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xBD017178EF1DB222BD0693C8EF1DB222 INT RAM : 0x00040000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : LeEco ProdName : Le2_CN1 ProdModel : Le X620 Device : le_x6 AndroidVer: 6.0 MTKxCPU : MT6797 MTKxPRJ : alps-mp-m0.mp9-V1.0.1_hq6797.6c.b1a.m_P2 EXTRA : LCD : Not info available :( LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : ov16880_mipi_raw CAM [1] : ov16880_primax_mipi_raw CAM [2] : imx230_mipi_raw CAM [3] : imx230_primax_mipi_raw CAM [4] : ov8865_mipi_raw CAM [5] : ov8865_sunny_mipi_raw MODEM : mt6797_sp_lwctg_mp2_umoly0020_prod LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:11 Reconnect Power/Cable! Last edited by Abzal; 10-11-2016 at 13:30. |
10-11-2016, 20:47 | #56 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | |
10-12-2016, 08:42 | #58 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Quote: Antiviruhttp Already Dissable , Or Try A Nother PC .Alwys Eurr. User Media - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting Plz Plz CM2 Team Help Me | |
The Following User Says Thank You to ahmer5050 For This Useful Post: |
10-12-2016, 09:23 | #59 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: my dream
Member: 664744 Status: Offline Thanks Meter: 156 | huawei LUA-U22 read info Quote:
10-12-2016, 12:30 | #60 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1823113 Status: Offline Thanks Meter: 0 | just bought cm2 dongle, and Oppo F1s is my first try to read, but one thing make me confuse, as we know that F1s has mt6750 inside, but why CM2 read it for mt6755 scatter, and all went wrong after i tried to flash it, and my beloved F1s go to beautiful sleep, untill i got a tested firmware with mt6750 scatter, then my phone get alive again but i believe in the next update, the team will get rid of this problem |
