08-27-2017, 12:36 | #1 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity-Box Chinese Miracle-2 RDA v1.06 released LOD flashing support and other stuff RDA SP Platform - FlashEngine updated for RDA SP881x series RDA FP platform - LOD ( Factory Flash File format ) flashing supported! Tested with 8851/C and older CPU's, down to CT112x. - FlashID database updated and revised - CompileInfo extraction revised - UserCode reading revised Other - Repair security revised SP/FP - New FP Signed drivers uploaded to support ( x86 and x64 ) - Connection stack updated - Some bugfixes and improvements Download link Upload file to Support - Download files via Torrent Infinity-Box 12 years (2005 - 2017) updates and support as nobody else - News Twitter - Facebook - Telegram |
The Following 46 Users Say Thank You to InfinityHelp For This Useful Post: |
08-27-2017, 13:14 | #2 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Soul Society
Member: 2669319 Status: Offline Thanks Meter: 421 | Great Update Team. BTW, what happen to your CM2MTK V2 countdown??? Exceeds Already... |
The Following 5 Users Say Thank You to Taguro-GSMLover For This Useful Post: |
08-28-2017, 08:08 | #6 (permalink) |
Insane Poster Join Date: Mar 2016
Member: 2543662 Status: Offline Thanks Meter: 395 | Great work infinity team Please release cm2 mtk update and fix range check error I tried to solve this problem 2 weeks but not success i uninstalled cm2 mtk setup and delete mtk folder from c drive infinity box and again install but not success i uninstalled all my pc driver and install again but not done and clean card formatted my pc and again install setups and drivers but problem same range check error Sent from my XT1068 using Tapatalk |
08-28-2017, 16:26 | #10 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2303399 Status: Offline Thanks Meter: 29 | my proud team please please please please please give him mtk new update urjant mtk 6735 / 6735m cpu not support this time please pick it this cpu 6535m chip add complete support info format flash frp and imei repair option mtk 6735 cpu huawei and samsung new models new chips added please |
The Following User Says Thank You to naseer raza For This Useful Post: |
08-29-2017, 08:50 | #11 (permalink) |
Freak Poster Join Date: Jul 2013 Location: A Planet Called Earth Age: 34
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | no security options in rda module...plzz help |
The Following User Says Thank You to server22 For This Useful Post: |
08-30-2017, 02:19 | #13 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Chinese Miracle II [RDA module] v 1.05 Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Ok Reboot Phone Elapsed: 00:01:02 Reconnect Power/Cable! I use 1.6 ver but shows 1.5 |
The Following User Says Thank You to dyo For This Useful Post: |
08-30-2017, 02:41 | #14 (permalink) | |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Cherry mobile B200 Flash done Quote:
08-30-2017, 09:56 | #15 (permalink) |
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | H-mobile security repair problem Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 260CF0C0 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! |
