10-04-2017, 17:25 | #91 (permalink) |
Freak Poster Join Date: Jul 2004 Location: nigeria Age: 41
Member: 73254 Status: Offline Sonork: 100.1583566 Thanks Meter: 13 | I have dump file, can you make unlock Attached Name: IMG_20170630_104115.jpg |
10-04-2017, 19:25 | #92 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Not got any yet, which are compatible with those firmwares ( even display not work. Not enough to start dwvice and run sim card ). | |
10-05-2017, 07:32 | #96 (permalink) |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | Fed-up with this even after adding a file named uk.off in scr folder it dosent work don't know what the hell I am doing wrong QLM also have this problem but not a big issue I badly need scr to work Any way thank you for trying to help. BTW mtk ,spd rda all exe work with no problem. |
10-05-2017, 08:19 | #98 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: PAKISTAN Age: 38
Member: 689829 Status: Offline Sonork: 100.1651716 Thanks Meter: 102 | Quote:
The Following 4 Users Say Thank You to jaan_e_ahsan45 For This Useful Post: |
10-05-2017, 08:30 | #99 (permalink) | |
Member: 433257 Status: Offline Thanks Meter: 43 | Quote:
The Following User Says Thank You to maximas007 For This Useful Post: |
10-06-2017, 16:12 | #101 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | RDA F PHONE Format Done Quote:
10-10-2017, 14:49 | #102 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Türkiye
Member: 395431 Status: Offline Thanks Meter: 458 | yes supported read write flash format ok . write ime http://forum.gsmhosting.com/vbb/f296...l#post12717740 Quote:
The Following User Says Thank You to turkcellgsm For This Useful Post: |
10-10-2017, 15:35 | #103 (permalink) | |
No Life Poster Join Date: May 2006 Location: Mountains
Member: 276322 Status: Offline Thanks Meter: 293 | Quote:
Operation : Identify [ v1.00 ] Code: ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0xA009B570 BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Identify : Code Integrity Check pass! Device Info Details : [0] : X06_HY_240x320_AOLIXIN_3310_HCLZX [1] : 6533 [2] : SC6533G_FP [3] : SC6533G [4] : pasw_SC6533 [5] : flsh_spi32m [6] : nv3029e/SV3029F/SV3029G/SV3029H/GC9301/gc9304/GC9305/gc9306/ili93418b/st7789r8bit [7] : sp0820/BF3703/bf3901/gc6133 [8] : SCbt_6533 [9] : SCfm_6533G [10] : release [11] : 2017-05-27_16:10:12 [12] : X06_3310_HCLZX_3310_20170527_D_V02_6820 Done! Elapsed: 00:01:29 Reconnect Power/Cable! Code: ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0xA009B570 BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Read done, 0x00400000 Verify FlashContent MCU verified CAL verified FAC verified Device Info Details : [0] : X06_HY_240x320_AOLIXIN_3310_HCLZX [1] : 6533 [2] : SC6533G_FP [3] : SC6533G [4] : pasw_SC6533 [5] : flsh_spi32m [6] : nv3029e/SV3029F/SV3029G/SV3029H/GC9301/gc9304/GC9305/gc9306/ili93418b/st7789r8bit [7] : sp0820/BF3703/bf3901/gc6133 [8] : SCbt_6533 [9] : SCfm_6533G [10] : release [11] : 2017-05-27_16:10:12 [12] : X06_3310_HCLZX_3310_20170527_D_V02_6820 Saved to : C:\Users\TIMUR\Desktop\ Saved as : SC6533G_4MiB_X06_HY_240x320_AOLIXIN_3310_HCLZX_X06_3310_HCLZX_3310_20170527_D_V02_6820_2017-05-27_161012.ilod Done! Elapsed: 00:01:27 Reconnect Power/Cable! | |
The Following User Says Thank You to gulka For This Useful Post: |
10-10-2017, 16:40 | #104 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | nokia 108 sc6533g format and read firmware done Code: Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.00 Operation : Identify [ v1.00 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Identify : Code Integrity Check pass! Device Info Details : [0] : SC6533 [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_hs8292u [5] : flsh_spi32m [6] : ili9163c/gc9102/gc9105/st7735r/HT2018/s6d0144 [7] : byd3A01/gc6133/gc6123/sp0820 [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2017-05-02_18:27:58 [12] : HA001_128160_JDR_Q4_U2_EnFrArPeRu_R47107 Done! Elapsed: 00:00:34 Reconnect Power/Cable! Operation : Reset Settings [ v1.00 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:00:28 Reconnect Power/Cable! Operation : Read Flash [ v1.00 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Read done, 0x00400000 Verify FlashContent MCU verified CAL verified FAC verified Device Info Details : [0] : SC6533 [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_hs8292u [5] : flsh_spi32m [6] : ili9163c/gc9102/gc9105/st7735r/HT2018/s6d0144 [7] : byd3A01/gc6133/gc6123/sp0820 [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2017-05-02_18:27:58 [12] : HA001_128160_JDR_Q4_U2_EnFrArPeRu_R47107 Saved to : C:\Users\ss\Desktop\nokia 105 sc6533\ Saved as : SC6533G_4MiB_SC6533_HA001_128160_JDR_Q4_U2_EnFrArPeRu_R47107_2017-05-02_182758.ilod Done! Elapsed: 00:00:51 Reconnect Power/Cable! |
The Following User Says Thank You to sky73 For This Useful Post: |
10-14-2017, 04:24 | #105 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 267265 Status: Offline Thanks Meter: 8 | can you please help me i download scr module i install but cant open..whats wrong?it says.."DONGLE FIRMWARE VERSION ;V01.34 DONGLE FIRMWARE IS OUTDATED! DOWNLOAD DONGLE MANAGER FROM SUPPORT AND UPDATE FIRMWARE! now i download dongel manager and try ko update.. === DongleManager [Infinity] v1.70 [10/14/2017 11:13:32] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 2 HWID: 000259ECFF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 234659EC Firmware version: 0134.02 === Process started: 10/14/2017 11:13:36 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! what wrong?do i need to buy activation?please help..thank ps..cm2mtk,cm2spd,cm2qlm,all is ok working... |
