Old 10-04-2017, 17:25   #91 (permalink)
ramongaru's Avatar
Member: 73254
Sonork: 100.1583566
Thanks Meter: 13
Telma k1s and X034duo RDA/ COOLSAND 8851a, 8851cl file unlocking solution
I have dump file, can you make unlock
Attached
Old 10-04-2017, 19:25   #92 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Attached
Hello. Still trying to find similar hw samples to make something.
Not got any yet, which are compatible with those firmwares ( even display not work. Not enough to start dwvice and run sim card ).
The Following User Says Thank You to JayDi For This Useful Post:
Old 10-04-2017, 19:26   #93 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by maximas007 View Post
Tried all the tricks cannot enable security tab please help uk is off and no file as uk off in dongle manager folder pls help
Need uk off in dongle.
Need uk.off file in sw folder.
Old 10-05-2017, 06:03   #94 (permalink)
maximas007's Avatar
Member: 433257
Thanks Meter: 43
would be grateful if you could pm me the UK.off file I couldn't find it any where
BTW. UK ALREADY OFF IN DONGLE
Old 10-05-2017, 06:08   #95 (permalink)
JayDi's Avatar
Member: 462970
You can make it by yourself. Rename any file to uk.off
Old 10-05-2017, 07:32   #96 (permalink)
maximas007's Avatar
Member: 433257
Thanks Meter: 43
Fed-up with this even after adding a file named uk.off in scr folder it dosent work don't know what the hell I am doing wrong QLM also have this problem but not a big issue I badly need scr to work
Any way thank you for trying to help.
BTW mtk ,spd rda all exe work with no problem.
Old 10-05-2017, 07:57   #97 (permalink)
JayDi's Avatar
Member: 462970
All new releases of modules will force you to same manipulation.
Make sure your uk.off file have exactly "off" extension, not txt or etc.
Old 10-05-2017, 08:19   #98 (permalink)
jaan_e_ahsan45's Avatar
Member: 689829
Sonork: 100.1651716
Thanks Meter: 102
here it is uk.off place in SCR main folder and done.
The Following 4 Users Say Thank You to jaan_e_ahsan45 For This Useful Post:
Old 10-05-2017, 08:30   #99 (permalink)
maximas007's Avatar
Member: 433257
Thanks Meter: 43
thank you buddy you saved my day.
The Following User Says Thank You to maximas007 For This Useful Post:
Old 10-05-2017, 08:31   #100 (permalink)
Member: 2764645
Thanks Meter: 64
here is any activation server for cm2
Old 10-06-2017, 16:12   #101 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
RDA F PHONE Format Done
Operation : Reset Settings [ v1.00 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00200000
BOOT_INIT : 0xAC2CDD90
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:27
Reconnect Power/Cable!
Old 10-10-2017, 14:49   #102 (permalink)
turkcellgsm's Avatar
Member: 395431
Thanks Meter: 458
Originally Posted by ghr View Post
nokia 3310 suported or not
yes supported read write flash format ok . write ime http://forum.gsmhosting.com/vbb/f296...l#post12717740
Card found : xxxxx , v0136
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.00
Operation : Identify [ v1.00 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Identify : Code Integrity Check pass!
Device Info Details :
[0] : SC6533
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[6] : nv3029f/nv3029g/st7789/gc9305/ili9325
[7] : byd3A01/gc6133/gc6123/sp0820
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2017-06-19_15:43:13
[12] : HA001_240320_HZX_3310_GOODLUCK_TuEnFrPoArPe_R50157
Done!
Elapsed: 00:01:59
Operation : Read Flash [ v1.00 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x000000F1
BOOT_INIT : 0x00600000
BOOT_MODE : UNKNOWN
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Read done, 0x00400000
Verify FlashContent
MCU verified
CAL verified
FAC verified
[0] : SC6533
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
Saved to : C:\Users\uzmanbilir1\Desktop\
Saved as : SC6533G_4MiB_SC6533_HA001_240320_HZX_3310_GOODLUCK _TuEnFrPoArPe_R50157_2017-06-19_154313.ilod
Done!
Elapsed: 00:01:29
The Following User Says Thank You to turkcellgsm For This Useful Post:
Old 10-10-2017, 15:35   #103 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Verify FlashContent
MCU verified
CAL verified
FAC verified
[0] : SC6533
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2017-05-25_20:28:12
[12] : HA001_240320_HZX_3310_GOODLUCK_EnFrPeArUr_R48823
Saved to : D:\Other\Nokia 3310\
Saved as : SC6533G_4MiB_SC6533_HA001_240320_HZX_3310_GOODLUCK _EnFrPeArUr_R48823_2017-05-25_202812.ilod
Done!
Elapsed: 00:03:15
Nokia 3310 other phone/ read info & firmware Done
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_INIT : 0xA009B570
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
[0] : X06_HY_240x320_AOLIXIN_3310_HCLZX
[1] : 6533
[2] : SC6533G_FP
[3] : SC6533G
[4] : pasw_SC6533
[5] : flsh_spi32m
[6] : nv3029e/SV3029F/SV3029G/SV3029H/GC9301/gc9304/GC9305/gc9306/ili93418b/st7789r8bit
[7] : sp0820/BF3703/bf3901/gc6133
[8] : SCbt_6533
[9] : SCfm_6533G
[10] : release
[11] : 2017-05-27_16:10:12
[12] : X06_3310_HCLZX_3310_20170527_D_V02_6820
Done!
Elapsed: 00:01:29
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Verify FlashContent
MCU verified
CAL verified
FAC verified
[1] : 6533
[2] : SC6533G_FP
[3] : SC6533G
[4] : pasw_SC6533
[5] : flsh_spi32m
[8] : SCbt_6533
[9] : SCfm_6533G
[10] : release
Saved to : C:\Users\TIMUR\Desktop\
Saved as : SC6533G_4MiB_X06_HY_240x320_AOLIXIN_3310_HCLZX_X06_3310_HCLZX_3310_20170527_D_V02_6820_2017-05-27_161012.ilod
Done!
Elapsed: 00:01:27
The Following User Says Thank You to gulka For This Useful Post:
Old 10-10-2017, 16:40   #104 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
nokia 108 sc6533g format and read firmware done
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
[0] : SC6533
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[6] : ili9163c/gc9102/gc9105/st7735r/HT2018/s6d0144
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2017-05-02_18:27:58
[12] : HA001_128160_JDR_Q4_U2_EnFrArPeRu_R47107
Done!
Elapsed: 00:00:34
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Done!
Elapsed: 00:00:28
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Verify FlashContent
MCU verified
CAL verified
FAC verified
[0] : SC6533
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
Saved to : C:\Users\ss\Desktop\nokia 105 sc6533\
Saved as : SC6533G_4MiB_SC6533_HA001_128160_JDR_Q4_U2_EnFrArPeRu_R47107_2017-05-02_182758.ilod
Done!
Elapsed: 00:00:51
The Following User Says Thank You to sky73 For This Useful Post:
Old 10-14-2017, 04:24   #105 (permalink)
Member: 267265
Thanks Meter: 8
can you please help me i download scr module i install but cant open..whats wrong?it says.."DONGLE FIRMWARE VERSION ;V01.34
DONGLE FIRMWARE IS OUTDATED!
DOWNLOAD DONGLE MANAGER FROM SUPPORT AND UPDATE FIRMWARE!
now i download dongel manager and try ko update..
=== DongleManager [Infinity] v1.70 [10/14/2017 11:13:32] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Gemalto e-gate Smart Card 2
HWID: 000259ECFF021982
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 234659EC
Firmware version: 0134.02
=== Process started: 10/14/2017 11:13:36 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
what wrong?do i need to buy activation?please help..thank
ps..cm2mtk,cm2spd,cm2qlm,all is ok working...
Page generated in 0.27034 seconds with 10 queries
