10-28-2017, 17:55 | #121 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: india
Member: 704044 Status: Offline Thanks Meter: 212 | Quote:
File please? Sent from my iPhone using Tapatalk | |
10-28-2017, 19:35 | #122 (permalink) | |
Junior Member Join Date: May 2015 Location: colombia
Member: 2389722 Status: Offline Sonork: soporte Thanks Meter: 5 | Quote:
when I added imei repair for spd and pra this model g6533g | |
10-28-2017, 19:54 | #123 (permalink) |
Crazy Poster Join Date: Sep 2007 Location: pangasinan philipines
Member: 582552 Status: Offline Thanks Meter: 9 | can i ask you brother? what example cellphone model chips set sc6533g like!! im using your software cm2 please i need your sample model list think you....... |
10-29-2017, 06:23 | #124 (permalink) |
Freak Poster Join Date: Jan 2008 Location: PAKISTAN Age: 38
Member: 689829 Status: Offline Sonork: 100.1651716 Thanks Meter: 102 | The link is in the post but OK i'll copy for you here it is.. Download UK.off paste in SCR folder and you are all done restart SCR and IMEI option is there... |
The Following User Says Thank You to jaan_e_ahsan45 For This Useful Post: |
10-29-2017, 17:26 | #125 (permalink) |
Insane Poster Join Date: Feb 2014 Location: karachi Age: 35
Member: 2128958 Status: Offline Thanks Meter: 39 | china 3310 sc6533g ok file tested China nokia 3310 sc6533g firmware read by asif.com Rasheedabad link......https://www.4shared.com/rar/mA0-C3SA..._firmware.html |
The Following User Says Thank You to asif.khan For This Useful Post: |
11-01-2017, 17:13 | #126 (permalink) | |
11-02-2017, 11:06 | #128 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: A Planet Called Earth Age: 34
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | Quote:
there is no option in it i turn off uk edition too but still no option in this module | |
11-13-2017, 05:45 | #130 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000117FF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
11-13-2017, 05:47 | #131 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Read PatternLock [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... [Read Mode] : HSUSB : 0x3000 Read Ok , decrypt PatternLock Sequence : 125698743 Done! Elapsed: 00:02:47 Reconnect Power/Cable! |
11-13-2017, 05:48 | #132 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ¾µ´Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
11-13-2017, 05:48 | #133 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-13-2017, 05:48 | #134 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Read User Code [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ::ðBoot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 9922 Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
11-13-2017, 05:49 | #135 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done |
