12-28-2017, 08:51 | #63 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR SPRD mode : SC6531 : REV : 0000 : NOR Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! ERROR : Structure Identification failed! Unsupported device! Done! Elapsed: 00:00:39 Reconnect Power/Cable! SPRD mode : SC6531 : REV : E000 : NOR Operation : Identify [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : C000 : NOR Operation : Identify [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : 357725060051795 IMEI[2] : 357725060151793 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! ERROR : Structure Identification failed! Unsupported device! Done! Elapsed: 00:00:24 Reconnect Power/Cable! SPRD mode : SC6531 : REV : A000 : NOR Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 ERROR : BOOT ACK not received! Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 ERROR : FDL start verify failed! 0000008E:8100220053707265 Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR Operation : Identify [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : 357725060051795 IMEI[2] : 357725060151793 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Done! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 ERROR : BOOT ACK not received! Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL Start Failed! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Done! Elapsed: 00:00:32 Reconnect Power/Cable! Operation : Read UserCode [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! Error : PMT info not found! Damaged device MCU code! Send log and report.log to support! Include device info also! Reconnect Power/Cable! SPRD mode : SC6530 : REV : 0000 : NOR Operation : Identify [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6530 : REV : 0000 : NOR |
12-28-2017, 10:48 | #68 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @kothamamun, use CODE tag instead of wasting space and make post unreadable. If have problems - post just ONE operation logs. If you smashing buttons just for fun - then it time to go in other section. |
12-28-2017, 11:01 | #70 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
I tried by select sc6530 but not work. It is new spd features phone chipset sc6530GS. | |
12-28-2017, 12:11 | #72 (permalink) |
Freak Poster Join Date: Jun 2012 Location: united kingdom
Member: 1777637 Status: Offline Sonork: 100.1616860:md Thanks Meter: 45 | Hi, thankd for very usefull update, when u wil add for unlocl imo dash mobile uk tesco network? if u need phone please contact me i can send u one phone. Thanks my sonork id is 100.1640308 |
