02-15-2019, 09:49 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Infinity-Box CM2MT2 v2.05 released Latest version for *InfinityBox_install_CM2MT2_v2.05* as been released Index of pub/software/ |
The Following 5 Users Say Thank You to Yusuf Lawal For This Useful Post: |
02-15-2019, 10:20 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: Alwar Age: 47
Member: 1311498 Status: Offline Sonork: 100.1662995 Thanks Meter: 513 | Infinity-Box MTK CM2MT2 v2.05: New models and features ! Base: Base - Secure boot - ARB verification revised for some secure configs and chips FWFlasher: FWFlasher - Flash core updated FWFlasher - SecureFlash on Legacy phones revised ( SECCFG options and other issues fixed ) FWFlasher - MT6753/MT6752 flashing revised FWReader: FWReader - More accurate type detection on LEGACY lines FWReader - More types supported for safe read FWReader - Info reading improved Service: Service - "SimLock Reset" option activated - used to rollback all LockSettings to default Service - Format FS revised Service - Repair BB revised Service - NVRAM module updated Platform: Platform - MT6771 support optimized Platform - MT6753 support optimized Platform - MT8127 support optimized Loaders: LoaderDB - Lot of new agents included (Alcatel, Moto, Lava and others) Other: Other - Many different small changes and fixes Other - Some kind of GUI changes for better user expirience Other - ErrorHandling updated - more detailed hints/explanation of troubles during service process Other - EMI Module updated Other - Preloader tools, Preloader init and other related stuff updated Other - Scatter handling optimized for some vendor-specific stuff Other - Automatic backup revised (manual tuneup fix) Other - Partial LEGACY NAND support (complete boot/verify) - Identify option works now on some devices Info: Info: Alcatel support for NEW line devices restricted by PRELOADER level ONLY! Some partitions are PROTECTED! BROM mode not supported for now ( due remote SLA ) Info: LEGACY secure flashing now pass at any base settings but IN SOME RARE CASES (like Huawei and similar) it may lead to BaseBand and other problems. Solution - REFLASH using CORRECT DA! Info: ARB nowdays appearing on more devices, make sure about you FLASH SAME version. (Identify ARB LOG and SW load LOG ) Not upgrade to newer ones, if need make some extend service etc. ! |
The Following 5 Users Say Thank You to rameshwarpooja For This Useful Post: |
02-15-2019, 10:46 | #3 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | HuaweiIf team add : manual save setting for every phone model and for DA loader ( protocol type ; EMI setting; boot mode and other setting ) it will be great for all users And CM2MT2 will have big size with LoaderDB file its great to add auto download LoaderDB or separate LoaderDB from support if updated Last edited by rebainoor; 02-15-2019 at 10:53. |
The Following 5 Users Say Thank You to rebainoor For This Useful Post: |
02-15-2019, 12:01 | #4 (permalink) |
Insane Poster Join Date: Jan 2016 Location: algeria...biskra...oumache
Member: 2511482 Status: Offline Thanks Meter: 12 | Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : USB Serial Device (COM47) MODE : PRELOADER PORT PORT : 47 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Oppo : F7 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! for OPPO F7....what doe's mean that |
