Infinity box failed. Infinity box failed to format a china mobile model and photo here. Cpu type.6228. Model no.A808 only. connector type trend t100. 1........8 4=GND 5=TXD 8=RXD ==== log: [10/28/2008 2:04:05 PM] ==== COM20 [Serial2] selected Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 74 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/28/2008 2:05:30 PM] ==== COM20 [Serial2] selected Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! Boot Fail Finished, time used: 5 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/28/2008 2:06:16 PM] ==== COM20 [Serial2] selected Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 104 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/28/2008 2:08:14 PM] ==== COM20 [Serial2] selected Action: reset settings Model: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 Connecting, wait... warning: wrong packet cs error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 93 sec Remove/Install battery now ! http://img252.imageshack.us/img252/416/image064vc9.jpg http://img370.imageshack.us/img370/9622/image081rp7.jpg |
But veepro box Done.phone is Alive PL2303 USB To COM20 Connecting VE-Dongles. VE-Dongles SN:********** VE-Dongles Version:V2.3 Datetime:2008-01 VE-Dongles data verify successed. register file is activate. file info.:GuangZhou VicEasy Company MTK6226 ---------------- open comport:COM20 please turnon your phone ,until connect success(press F4 Abort). connecting mobile phone. CPU Model:6228 downloading bootloader files ... bootloader files version:03.01 booloader operation in NAND Flash. Flash type:[HYNIX] HY27UF081G2M flash ID:00AD00F1 (0080001D) [56] flash size:08000000 (128.0M) Ext RAM size:00000000 Int RAM Size:00020000 Read flash information done. ---------------- open comport:COM20 please turnon your phone ,until connect success(press F4 Abort). connecting mobile phone. CPU Model:6228 downloading bootloader files ... bootloader files version:03.01 booloader operation in NAND Flash. Flash type:[HYNIX] HY27UF081G2M flash ID:00AD00F1 (0080001D) [56] flash size:08000000 (128.0M) Ext RAM size:00000000 Int RAM Size:00020000 format flash... >>operation done. |
Hello, I strongly suggest you to use good quality cables instead of buggy Prolific based cables, or at least search this forum and install good drivers for Prolific (link was posted here by support persons several times). |
this model flash file already in infinity support area .try to download from there |
M320_PCB04_GPRS_MT6228_S02.M3206V10_07_12_V1_3T06D 071217.BIN i need this file |
i format this set many times -----always suceesful |
