10-28-2008, 11:47 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Infinity box failed. Cpu type.6228. Model no.A808 only. connector type trend t100. 1........8 4=GND 5=TXD 8=RXD ==== log: [10/28/2008 2:04:05 PM] ==== COM20 [Serial2] selected Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 74 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/28/2008 2:05:30 PM] ==== COM20 [Serial2] selected Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! Boot Fail Finished, time used: 5 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/28/2008 2:06:16 PM] ==== COM20 [Serial2] selected Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 104 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/28/2008 2:08:14 PM] ==== COM20 [Serial2] selected Action: reset settings Model: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 Connecting, wait... warning: wrong packet cs error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 93 sec Remove/Install battery now ! |
10-28-2008, 11:53 | #2 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | But veepro box Done.phone is Alive PL2303 USB To COM20 Connecting VE-Dongles. VE-Dongles SN:********** VE-Dongles Version:V2.3 Datetime:2008-01 VE-Dongles data verify successed. register file is activate. file info.:GuangZhou VicEasy Company MTK6226 ---------------- open comport:COM20 please turnon your phone ,until connect success(press F4 Abort). connecting mobile phone. CPU Model:6228 downloading bootloader files ... bootloader files version:03.01 booloader operation in NAND Flash. Flash type:[HYNIX] HY27UF081G2M flash ID:00AD00F1 (0080001D) [56] flash size:08000000 (128.0M) Ext RAM size:00000000 Int RAM Size:00020000 Read flash information done. ---------------- open comport:COM20 please turnon your phone ,until connect success(press F4 Abort). connecting mobile phone. CPU Model:6228 downloading bootloader files ... bootloader files version:03.01 booloader operation in NAND Flash. Flash type:[HYNIX] HY27UF081G2M flash ID:00AD00F1 (0080001D) [56] flash size:08000000 (128.0M) Ext RAM size:00000000 Int RAM Size:00020000 format flash... >>operation done. |
10-28-2008, 17:00 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, I strongly suggest you to use good quality cables instead of buggy Prolific based cables, or at least search this forum and install good drivers for Prolific (link was posted here by support persons several times). |
05-15-2009, 19:24 | #4 (permalink) | |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
Infinity-Box Installatin Package v2.5a, Infinity-Box Shell, latest updates all-in-one | InfinitySupport | Infinity-Box | 44 | 03-06-2010 12:38 |
Infinity box drivers failing, help is appretiated | Vanman98 | Infinity-Box | 9 | 02-02-2009 22:02 |
Infinity box+pinfinder failed to detect pins | huong_huong_bg | Infinity-Box | 2 | 09-25-2008 01:48 |
Infinity Box End of Year Promotion : Buy 1 Infinity Box : Ger 1 Setool box for FREE | Infinity-Box | Main Sales Section | 0 | 12-31-2007 09:49 |
Infinity-Box Installatin Package v2.4a, Infinity-Box Shell, lates updates all-in-one | InfinitySupport | Infinity-Box | 28 | 12-03-2006 11:26 |
