03-16-2010, 15:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | infinity box huawei t156 not supported???? any one tell me that huawei t156 not supported infinity box plz tell me logs here => module version: v.1.73 => operation (3) started: COM12 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081038002187 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status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restore original mode... last error: No errors => operation finished ==> close_com_port thanks in advance |
The Following User Says Thank You to shh_903 For This Useful Post: |
03-16-2010, 18:40 | #3 (permalink) |
Member: 392149 Status: Offline Thanks Meter: 199 | infinity team not work the huawei t156 infinity team do something gives the unlocking huawei models t 156 g 1157 etc the problems are all pakistani user so what we do no unlocking huawei lg zte and motorola models what we thought the innfinty is dead tell me we waiting 4 ur ans |
03-17-2010, 09:08 | #4 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1015645 Status: Offline Thanks Meter: 114 | i have done this problem solve here is log sir COM4 selected module v1.76 Device: Huawei-T156 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20100315-184311.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20100315-184313.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20100315-184319.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20100315-184338.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 15 sec Remove/Install battery now ! |
Huawei T156 not supported | Tadiwa | SAGEM JTAG UNLOCKER | 1 | 02-23-2010 14:50 |
Huawei t156 not suppoted infinity box | mobiletuch | Infinity-Box | 3 | 11-08-2009 14:05 |
is huawei t156 flashing support in furious gold | zeeshan tayyab | FuriousGold | 2 | 10-04-2009 04:10 |
huawei t156 not unlock pls help me | danyalmeshal | FuriousGold | 2 | 08-24-2009 14:33 |
Huawei-T156 Not SP Unlock | naveed ali | Infinity-Box | 9 | 06-30-2009 07:50 |
