Old 05-11-2017, 10:43   #1 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Xiaomi HM 1S (Mi 2013029) error mi account remove
frp reset and full wipe(user/cach/frp) Done
Operation : Identify [ v1.11 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 400 [MSM8x26/28]
ID_BLOCK_S : 05DCA105
ID_BLOCK_I : 009150E1
ID_BLOCK_L : 826218E651DDCAC5A2977966A1F87850
ID_BLOCK_L : B7CE70DBDC47F77C915C31EEE40B2526
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0000C000/0000C000/00001000/00001000
Boot Ok!
Brand : Xiaomi
ProdName : ******
ProdModel : HM 1S
Device : ******
AndroidVer: 4.4.4
Manufact. : Xiaomi
QLMxCPU : MSM8226
Done!
Elapsed: 00:00:15
Reconnect Power/Cable!
Operation : Reset Settings [ v1.11 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Done!
Elapsed: 00:00:13
But reset xiomi account fail
Old 05-11-2017, 10:49   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Download factory FW for device
by memtool - read persist, write persist from factory fw.
Reboot phone.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-11-2017, 12:04   #3 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
which file ? should i select from factor FW
Old 05-11-2017, 12:33   #4 (permalink)
JayDi's Avatar
Member: 462970
Seems as persist not exists in flash bundle at all.
Does device have persist partition, did you see it in memory tool? Read it.
Old 05-11-2017, 12:34   #5 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
yes i already read it
but no file in firmware
[QUOTEOperation : Read Memory [ v1.11 ]
Reading selected partitions [1]
[0] Read partition : PERSIST
Saved to : C:\InfinityBox\CM2QLM\phdata\PERSIST.bin
Operation finished!][/QUOTE]
Last edited by .:Sanjh Phoenix:.; 05-11-2017 at 12:43. Reason: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Old 05-11-2017, 12:37   #6 (permalink)
JayDi's Avatar
Member: 462970
Upload that file for checking here.
Old 05-11-2017, 12:45   #7 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
in attachment in my prev pos
Old 05-11-2017, 13:08   #8 (permalink)
Member: 2317829
Thanks Meter: 2
try with djawirkey...product in indonesia
Old 05-11-2017, 13:14   #9 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
why are you spamming
its cm2 section no need other tools advertisement
Old 05-11-2017, 13:32   #10 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
write PERSIST.image done
from ******_global_images_JHCMIBL50.0_4.3_in_111a6a27b4 \******_global_images_JHCMIBL50.0_4.3_in
Operation Write Memory [ v1.11 ]
Write selected partitions [1]
[0] Write partition : PERSIST
Write from : C:\Documents and Settings\Mridula Soft\Desktop\******_global_images_JHCMIBL50.0_4.3_ in_111a6a27b4\******_global_images_JHCMIBL50.0_4.3 _in\images\persist.img
Write partition Ok!
Operation finished!
but no luck till lock
Old 05-11-2017, 14:04   #11 (permalink)
JayDi's Avatar
Member: 462970
Strange, seems as device store it somewhere else. will check it today.
Old 05-12-2017, 06:11   #12 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
I'm also try at Redmi 3s/3X ( land ) but not work mi account show again
Saved to : C:\Users\xxx\Desktop\PERSIST.bin
Operation finished!
Write from : C:\Users\xxx\Desktop\persist.img
Write partition Ok!
Operation finished!
Old 05-12-2017, 09:44   #13 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
http://forum.gsmhosting.com/vbb/member.php?u=462970
Dear JayDi
Any Solution ?
Old 05-12-2017, 11:34   #14 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Originally Posted by .:Sanjh Phoenix:. View Post
Dear JayDi
Any Solution ?
Write this PERSIST file & post result
Br - srinibas
Old 05-12-2017, 13:33   #15 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Br - srinibas
solved problem via flashing
The Following User Says Thank You to .:Sanjh Phoenix:. For This Useful Post:
Page generated in 0.26446 seconds with 10 queries
