08-30-2015, 08:58 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | infinity box module not open |
08-30-2015, 09:13 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
before some day u get same problem as i know in cdma section http://forum.gsmhosting.com/vbb/f633...ports-1973070/ | |
08-30-2015, 09:20 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Open HModule folder in c:/InfinityBox/HModule Open file setup.ini HModule folder. Find text "PortSearchMode=01" Replace it with "PortSearchMode=00" Run software again. Br. | |
08-30-2015, 10:00 | #4 (permalink) | |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
09-09-2015, 08:03 | #7 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | problem solve uninstall sprint connection manager and comports than it is open here is successfully read code and format w220 done read code done Code: COM5 [Serial3] selected module v1.38 Model: Motorola-W220 Action: "user code" Device must be POWERED-ON ! Connecting, wait... Phone connected. Working... code: 136552 Finished Warning ! Settings will be cleared, user data erased ! Do you want to continue ? ==== log: [9/9/2015 10:22:55 AM] ==== format done Code: COM5 [Serial3] selected module v1.38 Device: Motorola-W220 "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1230-000 software version: SCY-7- Check hardware done Read data ... reading Motorola-W220_eeprom_calibration-1... warning: wrong cs at 0x007F1400, retry... warning: wrong cs at 0x007F1400, retry... read error recovered warning: wrong cs at 0x007F5000, retry... read error recovered error: unexpected data: 020300010607 warning: wrong cs at 0x007F6400, retry... warning: wrong cs at 0x007F6400, retry... warning: wrong cs at 0x007F6400, retry... read error recovered error: unexpected data: F3F24A0BF7F6329C0908330E0D0CCC0EFFFFFCFDFFB3C8EBABAAADA4B2E3E0E1EEEFECED27F668E9EB9CCDD5D0C2C2D8F9DF5FDD7D99E9D9E5C7C4C5C2383F warning: wrong cs at 0x007F6800, retry... read error recovered warning: wrong cs at 0x007F6C00, retry... warning: wrong cs at 0x007F6C00, retry... warning: wrong cs at 0x007F6C00, retry... warning: wrong data size at 0x007F6C00, retry... warning: wrong cs at 0x007F6C00, retry... read error recovered warning: wrong cs at 0x007F9800, retry... read error recovered warning: wrong cs at 0x007FC400, retry... read error recovered warning: wrong cs at 0x007FC800, retry... read error recovered warning: wrong data size at 0x007FE000, retry... warning: wrong cs at 0x007FE000, retry... read error recovered warning: wrong cs at 0x007FFC00, retry... read error recovered file saved: C:\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20150909-102611.6AE.bin Read data done Check data ... Check data done Write ... flash: 89886400010001:89886400000000 Erase: ffs Write done Finished, time used: 1 min 9 sec Remove/Install battery now ! |
The Following User Says Thank You to rehmani For This Useful Post: |
