Old 07-11-2008, 22:48   #1 (permalink)
Member: 252848
Thanks Meter: 2
AVVIO 103A unable to unlock!!!!
hello
here i will post the download link of the 2 backup phone i have in my hands. one is generic unlocked and the other is the one that is unable to unlock for some reason.
http://rapidshare.com/files/12872479..._103a.rar.html
please let me know if you need anything else in rder to get solution for this problem.
Thank you Infinity team for GREAT SUPPORT PLEASE HELPPPP.
Best Regards
aikon2000
Old 07-12-2008, 10:29   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much !
Please, try to flash your Movistar phone with Avvio-103A_G1.0_C00.76_P192_I7880F_0714B01_V11CNx_Nov-30-2007_Generic_ver2.B1M.bin file from Infinity-Box support area and then try to unlock it.
Make backup before this operation for emergency case !
Let\'s see results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 07-13-2008, 18:00   #3 (permalink)
Member: 357413
Thanks Meter: 17
hello friends try flashing the flash mentioned but I get this error that is what will be happening
COM7 [Serial2] selected
Device: Avvio-103A
Checking data, wait...
Action: flash write
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sta_20080712-115558.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sec_20080712-115602.B1E.bin
reading [eeprom-complete]...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-complete_20080712-115610.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: Firmware
error: set erase range
error: erase failed: 00200000
Write Failed
Finished, Remove/Install battery now !
Time used: 35 sec
Old 07-13-2008, 18:14   #4 (permalink)
Member: 357413
Thanks Meter: 17
I friend again to support the infinity of this when I get what I want to unlock
Device: Avvio-103A
Action: unlock
unlock method-1
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sta_20080712-120542.B1E.bin
loading data...
data loaded
file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sec_20080712-120545.B1E.bin
file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-complete_20080712-120551.B1E.bin
reading additional data...
done
Check memory...
current status: #2, already unlocked
already done (mode-0), operation aborted
Check memory Failed
Time used: 34 sec
he also sent the full flash and eeprom read with infinity
http://rapidshare.com/files/12820505...O_103.rar.html
I hope that these data support to solve this problem with thanks avvio
greetings
Old 07-14-2008, 13:01   #5 (permalink)
Member: 130995
Hello,
It looks like it was some problems with flash files.
Files was re-uploaded, please, download new files and try to flash phone again.
Old 07-14-2008, 15:15   #6 (permalink)
Member: 357413
Thanks Meter: 17
Thank you friend will lower again the flash and will try flashearlo already I inform him about the results but ud regiere alos files of the support truth thank you regards
Old 07-14-2008, 15:56   #7 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
did you flash the phone i was uneable to flash it too i think im going to send phone to supporters
Old 07-14-2008, 17:30   #8 (permalink)
Member: 130995
@denisirias
Files was re-uploaded today, please, download new files and try to flash phone again.
Old 07-14-2008, 21:48   #9 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
Originally Posted by InfinitySupport View Post
@denisirias
now process start but stop when is going in 15% or in 4% all the time
i will send phone to you tomorrow morning that way you can do some test there
Old 07-15-2008, 17:50   #10 (permalink)
Member: 252848
Thanks Meter: 2
Hello again my friends
Here is the log for lates attempt to flash...The phone powers on and off now..after flash. i use both generic bin from main server.
==== log opened: [7/15/2008 12:40:08 PM] ====
Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe
Loading data, wait...
[Infinity Box] v1.50
S/N: 0C0E:***X
Wait...
Current model: Avvio-103A
Ready
COM5 ready
Loading file v.02...
Avvio-103A_G1.0_C00.76_P192_I7880F_0714B01_V11CNx_Nov-30-2007_Generic.B1M.bin loaded
COM5 [Serial2] selected
Device: Avvio-103A
Action: flash write
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check memory...
Check memory Done
Write...
reset...
done
Erasing: Firmware
Writing: Firmware
repair write error [004FE000]...
Ok
Ok
Write Done
Time used: 76 sec
Avvio-103A_G1.0_C00.76_P192_I7880F_0714B01_V11CNx_Nov-30-2007_Generic_ver2.B1M.bin loaded
Device: Avvio-103A
Action: flash write
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check memory...
Check memory Done
Write...
reset...
done
Erasing: Firmware
Writing: Firmware
Ok
Ok
repair write error [004FF000]...
Ok
Ok
Erasing: Firmware
error: erase failed: 007FC000
Write Failed
Time used: 87 sec
Old 07-15-2008, 21:04   #11 (permalink)
Member: 130995
Hello,
We will try to fix it ASAP
Old 07-22-2008, 16:34   #12 (permalink)
Member: 252848
Thanks Meter: 2
hello infinity team!!!
any new on the avvio 103a update?
aikon2000
Old 07-23-2008, 00:29   #13 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
aikon2000
i will send phone dont worry soon is going to be the solution
Old 01-27-2009, 18:02   #14 (permalink)
Member: 168246
Sonork: 100.110734
Thanks Meter: 79
can u confirm if is solution ready?
Old 01-27-2009, 19:23   #15 (permalink)
Member: 130995
Hello,
As I can see it was no any problems during already long time.
Just download latest Pana01 update from Infinity-Box support area and try to unlock phone.
j132 ips unlock done another ps unable to unlock unlock & flash Infinity-Box 21 05-03-2009 21:57
Avvio 103a Imposible To Unlock denisirias Infinity-Box 32 07-05-2008 15:31
to Lead - 8138 v106+ (R) unable to unlock ? Svetli Cruiser Suite 5 04-08-2005 16:53
unable to unlock t28 jokkergsm Old Ericsson Phones & Sony Phones 0 06-27-2002 17:22
I was unable to unlock Z5 with version 6.7.1/1SAT sat Sony 2 01-18-2002 16:47
Page generated in 0.24520 seconds with 9 queries
