02-11-2008, 07:57 | #16 (permalink) |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | CECT C2000 searching adapter at COM10... adapter found, version: 2000 Serial No: ****************************** pins: 18 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:15 Tx:16 time required: 155 sec Power On ! BR BnC |
02-11-2008, 11:10 | #19 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | 3D Sound Bluetooth Double SIM 99 ==> Pin 18 searching adapter at COM10... adapter found, version: 2000 Serial No: ************************************xx pins: 18 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:12 Tx:10 time required: 124 sec Power On ! br bnc |
02-12-2008, 10:38 | #20 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | Again.. N95 Slip Up 12 PIN searching adapter at COM10... adapter found, version: 2000 Serial No: ******************************xx pins: 12 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:7 Tx:6 time required: 51 sec Power On ! BR BNC |
02-12-2008, 11:56 | #21 (permalink) |
Freak Poster Join Date: Apr 2007 Location: bangladesh
Member: 487537 Status: Offline Thanks Meter: 61 | Thanks final solution about chaina phone pinout, please Infinity Team add others chaina cpu................waiting for the adaptor good work infinity team |
02-12-2008, 14:14 | #22 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | test again K-Touch B8890 18 PIN searching adapter at COM10... adapter found, version: 2000 Serial No: ..... pins: 18 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:5 Tx:6 time required: 45 sec Power On ! br bnc Last edited by InfinitySupport; 02-12-2008 at 18:02. Reason: s/n deleted |
02-13-2008, 08:50 | #23 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | test again TV Mobile ZT321 searching adapter at COM10... adapter found, version: 2000 Serial No: 0*************************** pins: 12 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6228 result: Rx:6 Tx:7 time required: 42 sec Power On ! br bnc Last edited by bestncheap; 02-13-2008 at 08:55. |
02-13-2008, 12:05 | #24 (permalink) |
Banned Join Date: Apr 2005 Location: GSX<=>SIC™
Member: 138762 Status: Offline Sonork: INFRACTION<=>SICK? Thanks Meter: 52 | i m estonished that people r thanking infinity team for this late update..as they have good engeniers they would b the first to give this auto detector solution .. |
02-13-2008, 16:36 | #25 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 583680 Status: Offline Thanks Meter: 47 | Cect T689 correct pinout found Quote:
02-13-2008, 17:07 | #26 (permalink) | |
Member: 583680 Status: Offline Thanks Meter: 47 | found pinout for unknown chinese mutant -PDA Gsm&Gsm,connector 12B Quote:
02-14-2008, 14:14 | #30 (permalink) | |
Member: 583680 Status: Offline Thanks Meter: 47 | model:cect V628 connector L20A Quote:
Cable Compatible For IP-L18C For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity-Power Cable Compatible For MC Tool / Infinity Box Pin Finder Adapter / Pad F | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Cable Compatible For IP-L20B For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity Box PIN FINDER Adapter Not working OK | hc_nuck23 | Infinity-Box | 2 | 04-14-2008 20:32 |
Infinity Box Pin-finder adapter : update box error | nekbil | Infinity-Box | 9 | 02-28-2008 18:02 |
