09-27-2011, 15:29 | #753 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | M1 Matrix software version: 1.26 platform: MT: MT6205, MT6217-MT6253 cable type: 1x12 (L12C) mode: Slow Fast searching adapter at COM5 (115200)... adapter found, version: 4000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 12, plain activation bytes/cycles: 2/2 detecting pins... detecting... result: Rx:9 Tx:8 time required: 1 sec Trying to Power-On... |
The Following User Says Thank You to amn32 For This Useful Post: |
10-30-2011, 13:06 | #754 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | QMobile Q3i. Cable: 2x5 (L10C) software version: 1.26 platform: MT: MT6205, MT6217-MT6253 cable type: 2x5 (L10C) mode: Slow Fast searching adapter at COM4 (115200)... adapter found, version: 4000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 10, plain activation bytes/cycles: 2/2 detecting pins... detecting... result: Rx:4 Tx:5 time required: 2 sec Trying to Power-On... |
11-03-2011, 14:36 | #755 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Azerbaijan,Baku Age: 39
Member: 520916 Status: Offline Sonork: 100.1605616 Thanks Meter: 53 | Hi all Infinity Pinfinder Users i bay new Infinity Combo Plus with cable in pack main including cable this eny can use infinity combo with this cable ? i try but not founded pin and basic contains come this ? main cable |
11-07-2011, 13:57 | #758 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! today i will try to search one phone using infinity combo box and GPG cable. I believe it must work as well , but i will post updated result later |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
11-22-2011, 12:10 | #759 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Nasaki m606 software version: 1.26 platform: MT: MT6205, MT6217-MT6253 cable type: 2x5 (L10C) mode: Slow Fast searching adapter at COM4 (115200)... adapter found, version: 4000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 10, plain activation bytes/cycles: 2/2 detecting pins... detecting... result: Rx:5 Tx:4 time required: 1 sec Trying to Power-On... Power is On |
11-25-2011, 11:14 | #760 (permalink) |
Junior Member Join Date: Dec 2009 Location: gsmhosting.com
Member: 1194475 Status: Offline Sonork: 100.1661150 Thanks Meter: 5 | I have just buy an Infinity combo pack (red color) and I have found that the DB26 port power cable does not delivery any power to phone. Now what to do for me? Please help!!!!!! |
11-27-2011, 22:30 | #761 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
do you get +5v on RJ45 port? between pins 7,8 (GND) and pin 6 (switchable power) Last edited by InfinityHelp; 11-28-2011 at 22:54. | |
12-08-2011, 16:36 | #763 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | G,right L800 software version: 1.26 platform: MT: MT6205, MT6217-MT6253 cable type: 1x8 (L8A) mode: Slow Fast searching adapter at COM5 (115200)... adapter found, version: 4000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 8, plain activation bytes/cycles: 2/2 detecting pins... detecting... result: Rx:3 Tx:2 time required: 1 sec Trying to Power-On... Power is On |
08-23-2014, 15:25 | #764 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Biafra
Member: 2128067 Status: Offline Thanks Meter: 16 | Infinity box pinfinder unable to work. Initialization finished searching adapter at COM29(115200)... too many retries (4) too many retries (4) too many retries (4) can not find adapter searching adapter at COM8(115200)... can not open COM8 can not open COM8 can not open COM8 can not find adapter searching adapter at COM9(115200)... can not open COM9 can not open COM9 can not open COM9 can not find adapter searching adapter at COM17(115200)... THEN AFTER THIS LEVEL IT WILL HANG ON PLEASE WHAT IS THE CASE WITH IT, I BOUGHT INFINITY BOX COMBO EDITION NEW |
08-23-2014, 22:54 | #765 (permalink) | |
What is COM port number assigned to BOX ? | |
Cable Compatible For IP-L18C For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity-Power Cable Compatible For MC Tool / Infinity Box Pin Finder Adapter / Pad F | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Cable Compatible For IP-L20B For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity Box PIN FINDER Adapter Not working OK | hc_nuck23 | Infinity-Box | 2 | 04-14-2008 20:32 |
Infinity Box Pin-finder adapter : update box error | nekbil | Infinity-Box | 9 | 02-28-2008 18:02 |
