infinity box questions Hi YellowBoss, I got some things to clarify. 1. What is the difference between tropical client and DT client? 2. I am planning to activate a few software for my infinity box, question is that will I be able to use the software simultaneously (e.g. I run infinity box main module then I ran gb key module if I have gbkey activation already). 3. What is the difference of the slim edition infinity box (2014 gpg model) to other boxes? Does it have a separate pinfinder or has the pinfinder built in already? I am referring to this box: http://gsmserver.com/nfs/product/854...-83-Cables.jpg br, |
1. Here is an answer: http://forum.gsmhosting.com/vbb/f296...l#post10615495 2. No, you can not run all software at the same time. Only one software can be run at a time. 3. "Slim" do not have built-in PinFinder, I think its "Base" pack. Please, check this manual, you can see detailed description of each package with pictures. http://server1.infinity-box.com/down...d_Packages.pdf Also you can ask GsmServer what is each their box means, they will give you detailed info for sure. |
thanks Thanks for the quick response. Also, another question, Can I activate the infinity box main software to my best dongle? I saw that some activations can be made to the best dongle (e.g. gb key and spt) but was not able to check if activating the main software is available. Thanks. |
Due to some technical reasons its not possible too. We hope to release this ability in some time but big technical work should be done to make it well. |
ok thanks please close |
