Old 10-16-2014, 22:37   #1 (permalink)
Member: 1766158
Sonork: 1618330
Thanks Meter: 21
infinity box questions
Hi YellowBoss, I got some things to clarify.
1. What is the difference between tropical client and DT client?
2. I am planning to activate a few software for my infinity box, question is that will I be able to use the software simultaneously (e.g. I run infinity box main module then I ran gb key module if I have gbkey activation already).
3. What is the difference of the slim edition infinity box (2014 gpg model) to other boxes? Does it have a separate pinfinder or has the pinfinder built in already? I am referring to this box:
http://gsmserver.com/nfs/product/854...-83-Cables.jpg
br,
Old 10-17-2014, 00:19   #2 (permalink)
Member: 1043909
Thanks Meter: 52,160
br,
Hello,
1. Here is an answer: Samsung Unlocker `Tropical` Software Test Reports
2. No, you can not run all software at the same time.
Only one software can be run at a time.
3. "Slim" do not have built-in PinFinder, I think its "Base" pack.
Please, check this manual, you can see detailed description of each package with pictures.
http://server1.infinity-box.com/down...d_Packages.pdf
Also you can ask GsmServer what is each their box means, they will give you detailed info for sure.
Old 10-17-2014, 01:44   #3 (permalink)
Member: 1766158
Sonork: 1618330
Thanks Meter: 21
thanks
Thanks for the quick response. Also, another question,
Can I activate the infinity box main software to my best dongle? I saw that some activations can be made to the best dongle (e.g. gb key and spt) but was not able to check if activating the main software is available.
Thanks.
Old 10-17-2014, 10:25   #4 (permalink)
Member: 1043909
Thanks.
Hello,
Due to some technical reasons its not possible too.
We hope to release this ability in some time but big technical work should be done to make it well.
Old 10-19-2014, 13:34   #5 (permalink)
Member: 1766158
Sonork: 1618330
Thanks Meter: 21
ok thanks please close
Page generated in 0.29469 seconds with 7 queries
