12-21-2006, 19:42 | #1 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 342890 Status: Offline Thanks Meter: 0 | infinity box register problem help infinity box smart card problem dongle maneger (infinty box )v1 .7 error sending apdu smartcard api error #2148532271 a communicationes error with the smart card has been detecdet retry the oparation helm wah dio du |
12-21-2006, 19:58 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Please, check this link: http://www.infinity-box.com/download/index.php You can see there: Infinity-Box_Installation_manual.htm (9 KB) Infinity_Drv_v1.2.exe (6977 KB) Please, install drivers according to manual before other software installation. |
12-22-2006, 15:51 | #3 (permalink) | |
Member: 342890 Status: Offline Thanks Meter: 0 | Quote:
problem continuation | |
12-22-2006, 18:45 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Possible reasons to see this kind of errors: lost contacts or cable problem (box to PC). drivers problem. PC problem. If you have any other smart-card reader (f.e external small card reader or other unibox with built-in card reader) you can try to insert Infinity-Box smart-card in this card reader. Don't use any kind of usb-hub ! Try to connect box to other PC USB slot. |
12-23-2006, 13:57 | #7 (permalink) |
Member: 342890 Status: Offline Thanks Meter: 0 | hi. we changed pc,cable but no response. after this we tried smart card with another box and same error. "communications error with the smart card." what will we do now?? thanks |
12-23-2006, 15:15 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, check installation procedure here: http://www.infinity-box.com/download/index.php Make installation step-by-step ! Check all steps and tell me at what step you see error. I need to know detailed problem description to give good advice !!! |
12-23-2006, 19:15 | #9 (permalink) |
Member: 342890 Status: Offline Thanks Meter: 0 | hi. i open dongle manager v17.i clicked "register dongle/upgrade dongle firmware". next.i checked auto login and start. it writes "locating emeralda server; emeralda server found;connecting to emeralda server;server connection succesfully established; s/n: 1*******,firmware: 0***.**; authenticating on server; authentication stage error:server reported error :[0005] authentication failed! wrong password or dongle not registered!" and a new windows comes; ""you need to make "registration" procedure before you start to use online upgrade system! press "yes" button to start registration process.if you are already registered in the online upgrade sytem,press no button."". i choose "yes". i write name/nick; email; reseller name and click to register. a new error window comes; "error sending APDU! smartcard API error #2148532271 a communications error with the smart card has been detected. retry the operation." i tried many times but can not login. |
12-23-2006, 19:26 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, check installation procedure here: http://www.infinity-box.com/download/index.php Install drivers according to instruction. Make installation step-by-step ! Check all steps and tell me at what step you see error. I need to know detailed problem description to give good advice !!! try to download Dongle Manager again. try to read donge info (use Dongle Manage). What is the result ? What other PC you used ? What other cables you used ? What other smart-card readers you tried to use ? |
12-23-2006, 19:31 | #11 (permalink) |
Member: 342890 Status: Offline Thanks Meter: 0 | when i read the info i take this: """Dongle S/N: 1******2 Firmware version: *******Standard Smart-card status: activated Smart-card Registration/Firmware upgrade required "UK edition" status: On Support area: http://www.infinity-box.com Support area Username: ****** Support area Password: ******* Identifier:****** If you can't login into support area: send mail with this info to [email protected] and your account will be activated as soon as possible. If you have problems during start software at first time: upgrade your dongle firmware."""" i tried 3 different pcs and cables. and i tried smart card with ustpro2 and take the same result "a communications error with smart card." |
12-24-2006, 08:49 | #12 (permalink) |
Insane Poster Join Date: Jun 2004 Location: austria
Member: 68701 Status: Offline Thanks Meter: 1 | hi. as you said,i tried smart card in another box at a different pc.there is no problem to read info but still can not register.everything looks like normal until registering. thanks.. |
12-26-2006, 17:18 | #14 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | @ murtacell where r u from? contact me on ICQ : 21260138 , MSN : [email protected] we will replace this smartcard for you Rgds Infinity-Box Team Last edited by Infinity-Box; 12-26-2006 at 17:46. |
Box registering problem | kava | Octopus LG/Octoplus LG | 3 | 01-19-2010 11:51 |
ub box register problem | alfox | Universalbox | 4 | 09-02-2008 02:33 |
Infinity Box login problem plz help... | anil2006 | Infinity-Box | 3 | 03-16-2008 22:12 |
infinity-box virus problem | lianghx | Infinity-Box | 1 | 06-16-2005 23:58 |
