02-04-2009, 10:26 | #1 (permalink) |
Freak Poster Join Date: Oct 2002 Age: 47
Member: 16899 Status: Offline Thanks Meter: 18 | Very need flash file for 8600d Very need flash file for chines Nokia 8600d RM-164. Not power on at all. After format with complit mode, same thing. It is looks like original - high copy, has 5 pin connector, like original noka 8600 mini usb. MTK 6225. And firmware info readed by infinity is ver. sw 1: LX686_06B_HW.Y686_QCIF_TH5_V4_9GTEST--080909.BIN ver. sw 2: Y686_QCIF_TH5_V4.9GTEST, 00000000 Pinout is hidden under imei sticker Can not find in support area, so please upload it, if you have. Thnx. |
02-04-2009, 15:50 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! unfortunately, we dont have nothing even similar to this version. to repair this phone you must find same version working set and use its backup |
02-04-2009, 17:00 | #3 (permalink) |
Member: 16899 Status: Offline Thanks Meter: 18 | Here you can can download working file, but it is under flashtool. Please convert it under infinity, so infinity users can use it. http://www.gsmforum.ru/showthread.php?t=37605 Let me know and I will test it with infinity. Thnx. |
02-05-2009, 08:24 | #5 (permalink) |
Member: 16899 Status: Offline Thanks Meter: 18 | COM8 [VCP1] selected module v2.74 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0603:000F boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE508009FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: LX686_06B_HW.Y686_QCIF_TH5_V4_9GTEST--080909.BIN ver. sw 2: Y686_QCIF_TH5_V4.9GTEST, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[LX686_06B_HW.Y686_QCIF_TH5_V4_9GTEST--080909.BIN]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[LX686_06B_HW.Y686_QCIF_TH5_V4_9GTEST--080909.BIN]_20090205-104223.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 655 sec Works, like a charm! 2 phones repaired, and they have RU corrected. Thank you Infinity team. |
!!!!! Needed, flash file for 8120 02 sfi file !!! | stemo | FuriousGold | 2 | 03-11-2009 20:08 |
i need flash file for G8000 and how to flash it??? | tsarkh | VygisToolbox | 2 | 08-08-2007 09:30 |
Very Need Flash Files For N77 | stepanok | Nokia Base Band 5 ( BB-5 ) | 2 | 06-16-2007 11:14 |
need flash file for c65 any version 810d flash | saeed-gsm | SIEM Service Tools | 2 | 12-27-2005 12:58 |
Need flash file for dejan 1.05 or full flash for 6250 with polish language | Rafal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-10-2002 20:13 |
